1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: [EXTERNAL] Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller
From: "Smith, Martin via Tech-talk" <[email protected]>
To: Mrinal Bera <[email protected]>
Date: Fri, 23 Feb 2024 12:42:14 +0000
Here is what we use at APS for the Televac MX200 device. In your boot file you would include
one of these, here I show 2 different MX200 devices.
#  For MM200 the Televac has two cold cathodes and a minimum of 2 convectrons
#       if STN is either 5/6 then the corresponding CV1 are 1/2 and CV2 are 3/4
#       if STN is either 3/4 then the corresponding CV is 1/2 and no CV2
#   MM200 expects "\r" for EOS for both inputs and outputs.
#!dbLoadRecords("db/vs.db","P=FE:28:ID:,GAUGE=VS1,PORT=TV1,ADDR=0,DEV=MM200,STN=5")
#!dbLoadRecords("db/vs.db","P=FE:28:ID:,GAUGE=VS2,PORT=TV1,ADDR=0,DEV=MM200,STN=6")
#!dbLoadRecords("db/vs.db", "P=TV:,GAUGE=VS1,PORT=Televac1,ADDR=0,DEV=MX200,STN=3 1 0 1")
#!dbLoadRecords("db/vs.db", "P=TV:,GAUGE=VS2,PORT=Televac1,ADDR=0,DEV=MX200,STN=4 0 2 2")
Let me know if I left anything out.
Marty
From: Tech-talk <[email protected]> on behalf of Mrinal Bera via Tech-talk <[email protected]>
Sent: Thursday, February 22, 2024 5:04 PM
To: Webb, Brad <[email protected]>; [email protected] <[email protected]>
Cc: [email protected] <[email protected]>
This Message Is From an External Sender
This message came from outside your organization.
Hi Brad and Abdalla,
Thank you for your template and protocol files. I had to modify the files a little bit to make it work for MPCQ Pump.
Best regards,
Mrinal
> On Feb 22, 2024, at 6:00 AM, Webb, Brad <[email protected]> wrote:
> Hi
> At SNS we use the DIGITEL QPC Controller from Gamma vacuum.
> We use the serial interface via a digi/moxa.
> Attached is our streamdevice interface (i.e., xxx.proto and
> xxx.template)
> -Brad
> On Thu, 2024-02-22 at 00:50 +0000, Mrinal Bera via Tech-talk wrote:
>>  Did anybody write EPICS support for the following devices? 1) Gamma
>> Controller(https: //www. gammavacuum. com/products/digitel-
>> controllers/3335/digitel-mpcq?number=MPCQ1PS1U1SSNI&c=17669) 2)
>> Televac MX200 Vacuum Controller
>> ZjQcmQRYFpfptBannerStart
>> ZjQcmQRYFpfptBannerEnd
>> 1) Gamma DIGITEL MPCQ Ion Pump
>> Controller(https://www.gammavacuum.com/products/digitel-controllers/3335/digitel-mpcq?number=MPCQ1PS1U1SSNI&c=17669
>> 2) Televac MX200 Vacuum Controller
>> (https://www.frederickscompany.com/products/mx200/)
>> Thanks,
>> Mrinal
>> Mrinal Kanti Bera, PHD
>> Beamline Scientist and Research Associate Professor
>> NSF’s ChemMatCARS, Pritzker School of Molecular Engineering,
>> The University of Chicago
>> 9700 S. Cass Ave Bldg 434D
>> Argonne, IL-60439
>> United States
>> Phone: +1-630-252-0472
Attachment: mx200.tar
Description: mx200.tar
Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller Mrinal Bera via Tech-talk
Re: [EXTERNAL] Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller Webb, Brad via Tech-talk
Re: [EXTERNAL] Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller Mrinal Bera via Tech-talk
Prev: Re: EPICS PLC5 Support Ralph Lange via Tech-talk
Next: Re: EPICS PLC5 Support Josh Fiddler via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: [EXTERNAL] Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller Mrinal Bera via Tech-talk
Next: EPICS Collaboration Meeting 2024 - Update status 조우성(빔운영팀) via Tech-talk
