1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: pvAccess assert error
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>, 'Michael Davidsaver' <[email protected]>
Date: Thu, 29 Feb 2024 23:02:24 +0000
Hi Mark,
On 2/29/24, 1:08 PM, "Tech-talk" [email protected] wrote:
It would have saved time and frustration if this bug and fix had been contained in the release notes for base 7.0.8 or pvAccessCPP 7.1.7.
Sorry, you can blame me for that although other than the code changes the only information I had about the fix when I updated the Release notes for pvAccessCPP 7.1.7 were these two git log messages from Freddie:
d4bb5952a Fix crash when toEcho empty
55ab0fd3b Avoid data() as it is c++11
They both came from this PR which doesn't give much more explanation.
- Andrew
Complexity comes for free, Simplicity you have to work for.
-----Original Message-----
Sent: Wednesday, February 28, 2024 4:22 PM
Cc: [email protected]
On 2/28/24 10:49, Mark Rivers wrote:
> Hi Michael,
> I sent a message to both tech-talk and core-talk at 4:31 PM CST yesterday.
> This is the tech-talk message:
> https://epics.anl.gov/tech-talk/2024/msg00292.php
> This is the core-talk message:
> https://epics.anl.gov/core-talk/2024/msg00042.php
Ah, this is an issue with MSVC debug builds which Freddie Akeroyd already found and fixed.
This fix is included in pvAccessCPP 7.1.7, which is bundled in epics-base 7.0.8.
> However, I did not actually then receive the message from tech-talk.  And it seems like maybe you did not either?  It seems like tech-talk archived it but did not send it?
> Mark
> From: Michael Davidsaver <[email protected]>
> Sent: Wednesday, February 28, 2024 12:31 PM
> Hi Mark,
> Am I being dense today?  I only see a screen capture attached to your original mail.
> On 2/28/24 10:25, Mark Rivers wrote:
>> Hi Michael,
>> Thanks for the reply.  I sent the full stack trace yesterday.
>> Mark
>> Sent: Wednesday, February 28, 2024 12:20 PM
>> On 2/26/24 16:37, Mark Rivers via Tech-talk wrote:
>>> Folks,
>>> I am running a new areaDetector camera.  It generates frames that are 4096x3072 pixels, 8-bit.  I can collect data from the camera at 150 frames/s using a BitFlow CoaXSpress card with no problems.  This is on a Windows PC.
>>> However, when I try to use pvAccess to read the data from the NDPluginPva plugin I get an assert error in pvAccess in my Windows application.  The error message is in the attachment.
>>> This happens when I use the ImageJ pvAccess plugin, and also when I use the following Linux command on another machine:
>>> $ pvmonitor 13BF1:Pva1:Image > /dev/null
>>> Any idea what the problem could be?  This is base 7.0.7.
>> At a guess, maybe another size()==0 situations as with:
>> https://github.com/epics-base/pvDataCPP/issues/50
>> If so, a full stack trace should point at the offending code.
pvAccess assert error Mark Rivers via Tech-talk
Re: pvAccess assert error Michael Davidsaver via Tech-talk
RE: pvAccess assert error Mark Rivers via Tech-talk
Prev: Re: archiver appliance quickstart installation Rong Huang via Tech-talk
Next: Re: archiver appliance quickstart installation Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: RE: pvAccess assert error Mark Rivers via Tech-talk
Next: Reg : How to use custom baud rate such as 125000 for ioc running on Linux Abhishek Mazumdar - STFC UKRI via Tech-talk
