I am getting this message output from st.cmd below. Do you have any suggestions.
Thank you,
Alex
drvAsynIPPortConfigure ("OC_SP", "255.255.255.255:4004:4004 UDP", 0, 0, 0)
# Commands
drvAsynIPPortConfigure ("OC_CMD", "10.67.146.77:4004 UDP*", 0, 0, 0)
## Load record instances
dbLoadRecords("/epics/iocs/cs700/db/cs700.db", "P=cs700:,Q=CS,PORT=OC_SP,PORTCMD=OC_CMD")
dbLoadRecords("/usr/lib/epics/db/asynRecord.db","P=cs700:,R=CS:ASYN:SP,PORT=OC_SP,ADDR=0,OMAX=1000,IMAX=1000")
dbLoadRecords("/usr/lib/epics/db/asynRecord.db","P=cs700:,R=CS:ASYN:CMD,PORT=OC_CMD,ADDR=0,OMAX=1000,IMAX=1000")
iocInit()
Starting iocInit
## EPICS R7.0.5
## Rev. R7.0.5-dirty
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 37299,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
CAS: CA beacon send to 10.67.146.255:5065 error: Operation not permitted
## Start any sequence programs
CAS: CA beacon send to 10.67.144.255:5065 error: Operation not permitted
#seq snccs700,"user=ptran1"
CAS: CA beacon send to 10.67.145.255:5065 error: Operation not permitted
