1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: Practical way to force the IOC to talk with one client
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>
Date: Tue, 19 Mar 2024 08:09:51 +0000
Hello All
Thanks for the suggestions. Sorry if things were not clear enough, I want certain IOCs to be “invisible” to all clients on the network except the gateway, so I want only the gateway to be able to talk with the IOC. I would like to try changing ports, what environment variable will achieve this on both the gateway and IOC sides?
Best Regards,
Abdalla.
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Monday, March 18, 2024 5:23 PM
To: EPICS Tech Talk <[email protected]>
Subject: Re: Practical way to force the IOC to talk with one client
I would say: It depends on what exactly you want to achieve...
If you want the Gateway to only contact specific IOCs - that's what Paul pointed out. Configure the Gateway (client side) to not broadcast name resolution requests and send them to the specific IOCs only.
If you want specific IOCs to only be contacted by the Gateway, there are multiple options:
ACFs: Limit read or write (or both) access to the Gateway user on the Gateway host. You played with that.
Move ports: Configure the IOCs to use a different port on their CA server and the Gateway to use that port on the client side. This will make the whole setup "invisible" to normal clients that don't know the special port number, but it doesn't provide access limitations.
Firewall: Configure the IOC host to only allow incoming CA name resolution traffic from the Gateway host.
Cheers,
~Ralph
Re: Practical way to force the IOC to talk with one client Ralph Lange via Tech-talk
Practical way to force the IOC to talk with one client Abdalla Ahmad via Tech-talk
Re: Practical way to force the IOC to talk with one client Paul Sichta via Tech-talk
Prev: Re:Re: epics snmp White via Tech-talk
Next: Re: AW: Building synApps and Galil ok, libGalilSupport.a not found Mark via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Practical way to force the IOC to talk with one client Ralph Lange via Tech-talk
Next: Re: Practical way to force the IOC to talk with one client Ralph Lange via Tech-talk
