Hi Matt (and anyone else interested), We did end up getting the EM32 sensors (we got the EM32-Xe, mostly for PoE support, but I think the Le would have worked just as well in retrospect and been a bit cheaper). Implementing the EPICS monitoring has been a low priority project for me, but I finally spent a bit of time on it. I took the script you sent and adapted it so that it's using pythonSoftIOC to create the records and IOC that holds the device data, mostly because I'm much more familiar with python than EPICS. That means that everything including the IOC creation is done in a single python script. In case you're interested, I've attached the script. I did appreciate the example script, I used your esensor class, lightly modified, and it definitely saved me a lot of time in parsing the json/xml! All the best. - Jesse Jesse Hopkins, PhD Deputy Director BioCAT, Sector 18 Advanced Photon Source On Mon, Nov 13, 2023 at 12:11 PM Matt Newville <[email protected]> wrote:
import asyncio
import traceback
import time
import json
import xml.etree.ElementTree as ET
from softioc import softioc, builder, asyncio_dispatcher
# import cothread
import requests
class ESensor:
""" read Esensor data, push to Epics PVs"""
def __init__(self, label, url, tempc_pv, tempf_pv, humid_pv, timestamp_pv):
self.label = label
self.url = url
# self.prefix = prefix
self.format = url.split('.')[-1]
self.tempf_pv = tempf_pv
self.tempc_pv = tempc_pv
self.humid_pv = humid_pv
self.timestamp_pv = timestamp_pv
if self.format == 'xml':
self.tattr = "tm0"
self.tunit = "tun0"
self.hattr = "hu0"
self.reader = ET.fromstring
elif self.format == "json":
self.tattr = "tmp"
self.hattr = "hum"
self.tunit = "tun"
self.reader = json.loads
def getval(self, source, attr, force_float=True):
if self.format == "xml":
try:
val = source.find(attr).text
except:
val = "-1"
try:
val = source.get(attr, -1.0)
except:
val = "-1"
if force_float:
try:
val = float(val)
except:
val = -1.0
return val
def read(self):
resp = requests.get(self.url, timeout=0.5)
tdat = self.reader(resp.content.decode("utf-8"))
tunt = self.getval(tdat, self.tunit, force_float=False)
tval = self.getval(tdat, self.tattr)
hval = self.getval(tdat, self.hattr)
return tval, tunt, hval
def update(self):
tval, tunit, hval = self.read()
if tunit in (0, '0', 'F'):
tval_f = tval
tval_c = (tval - 32)*5.0/9.0
else:
tval_c = tval
tval_f = (tval_c * 9.0/5) + 32
tval_f = float("%.3f" % tval_f)
tval_c = float("%.3f" % tval_c)
hval = float("%.3f" % hval)
self.tempc_pv.set(tval_c)
self.tempf_pv.set(tval_f)
self.humid_pv.set(hval)
self.timestamp_pv.set(time.ctime())
if __name__ == '__main__':
# Create an asyncio dispatcher, the event loop is now running
dispatcher = asyncio_dispatcher.AsyncioDispatcher()
esensors = []
# Define as prefix, url
sensor_defs = [
['18ID:EnvMon:D', "http://164.54.204.197/status.json"],
['18ID:EnvMon:C', "http://164.54.204.198/status.json"],
['18ID:EnvMon:A', "http://164.54.204.199/status.json"],
for sensor_def in sensor_defs:
prefix = sensor_def[0]
url = sensor_def[1]
# Set the record prefix
builder.SetDeviceName(prefix)
# Create some records
ai_c = builder.aIn('TempC', initial_value=0, DESC='Temperature (C)')
ai_f = builder.aIn('TempF', initial_value=0, DESC='Temperature (F)')
ai_h = builder.aIn('Humid', initial_value=0, DESC='Humidity (percent)')
si_t = builder.stringIn('TimeStamp', initial_value="", DESC='Timestamp of last update')
esensor = ESensor(prefix, url, ai_c, ai_f, ai_h, si_t)
esensors.append(esensor)
# Boilerplate get the IOC started
builder.LoadDatabase()
softioc.iocInit(dispatcher)
# Start processes required to be run after iocInit
async def update():
while True:
try:
[e.update() for e in esensors]
except Exception:
# traceback.print_exc()
pass
await asyncio.sleep(0.5)
dispatcher(update)
# Finally leave the IOC running with an interactive shell.
softioc.interactive_ioc(globals())
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
