1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: enable pvAccess by default
From: Florian Feldbauer via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 3 Apr 2024 08:58:43 +0200
Hey Timo,
following the guide you have linked in your mail, you use the "example" template. This one includes the PVAaccess libraries.
William is using the "ioc" template, which does not include the PVAaccess libraries by default.
There are some more differences in these two examples and I also prefer using the "ioc" template for my installations (including PVaccess).
But since I need to modify *App/src/Makefile anyways (to include my drivers) including PVaccess wasn't much of an issue for me so far.
Cheers,
Florian
On 4/3/24 08:49, Timo Korhonen via Tech-talk wrote:
Hi William,
Your post perfectly illustrates why we at ESS put the effort to create our “e3” environment 😉
I have not done plain builds for a while…it has started to annoy me that I have to scramble together all the drivers whereas with e3 I have all I need, already figured out.
However, to check, I just downloaded the latest release and compiled, and then created a base app, more or less following the steps as defined here.
Pretty much the same steps you have followed, as far as I can tell. (I think the same procedure has worked since EPICS 7 was released…not sure though.)
With makeBaseApp, I got an IOC with PVA server, without doing anything extra. Also, the IOC directory is ready to start integrating your drivers.
If you run the IOC you created, try the command “pvasr” in the shell (after iocInit). If the command is recognized, you have PVA server enabled.
I am not sure what exactly Andrew meant with softIocPVA executable, but I assume that if you just run an IOC without connecting to any particular hardware (thus “soft”), you can use the ready-made softIocPVA without doing anything extra.
Best regards,
Timo
From: Tech-talk <[email protected]> on behalf of William Kirstaedter via Tech-talk <[email protected]>
Reply to: William Kirstaedter <[email protected]>
Date: Tuesday, 2 April 2024 at 21:50
To: "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Hi Andrew,
I'm not too deep into the EPICS (core) "game".
so please elaborate what you mean with "softIOCPVA" executable...
let me explain what I do:
Up until now, I create new IOCs via the "makeBaseApp.pl" script.
mkdir myIOC
cd myIOC
makeBaseApp.pl -t ioc myIOC
makeBaseApp.pl -i -t ioc myIOC
after that, I have a "barebone" IOC which can be compiled but does nothing.
then, I can start integrating my devices.
Im doing this by, for example,
loading the async and streamdevice modules via the *App/src/Makefile and a $(TOP)/../RELEASE.local file,
then creating streamdevice proto files and a *db file for the records.
"make" the IOC.
Finally, I setup and load everything via the st.cmd and have a running system that can control my device.
this is where my idea came from:
right now, the *App/src/Makefile lacks statements to load the PVAserver (whatever it is called now, I always thought theres only one that got developed in EPICS4 and is now mostly done and always included in EPICS 7)
So, if I'd like to switch over from CA to PVA, or at least also enable PVA for all my IOCs, I'd have to add the QSRV library loading to every Makefile of every IOC that I maintain, and, more importantly, recall to add them everytime I create a new IOC for a new Lab or Device or whatever constellation...
Idk, my assumption as a user would have been that PVAserver is always available since I use EPICS 7 which combines "old-world" EPICS 3 and "new-world" EPICS 4 ?
also I wonder how big the ressources impact might be to run an additional PVAserver by default...
I'd assume modern low end hardware can handle that easily.
anyways, thanks for your reply :)
PS: also @Erico, thanks for your answer aswell, I see there might be quite a rabbithole regarding PVA stuff inside of EPICS 7 that I totally wasnt aware of...
William Kirstaedter
PP&B Computer Support Group
Fritz-Haber-Institut Berlin
Am 01.04.24 um 18:17 schrieb Johnson, Andrew N.:
Hi William,
On 3/31/24, 3:53 PM, "Tech-talk" [email protected] wrote:
I would like to know if you have already considered activating pvAccess
for softIOCs by default.
How is what you're asking for different than the softiocPVA executable that we already build in the pva2pva module?
I would probably adapt the Makefile template and simply copy the section
from the example IOC:
# Link QSRV (pvAccess Server) if available
ifdef EPICS_QSRV_MAJOR_VERSION
    _APPNAME__LIBS += qsrv
    _APPNAME__LIBS += $(EPICS_BASE_PVA_CORE_LIBS)
    _APPNAME__DBD += PVAServerRegister.dbd
    _APPNAME__DBD += qsrv.dbd
endif
Ultimately, this should not affect any old system, as pvAccess is only
loaded if it is also present in base?
PV Access has been part of Base since the first EPICS 7.0.1 release, but many sites aren't building it into all their IOCs — at the APS we use it in AreaDetector camera IOCs and our DAQ systems, but don't build it into our regular EPICS 7 IOCs yet. The extra libraries and threads that it starts would take up resources on our systems.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
thanks in advance,
William Kirstaedter
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: enable pvAccess by default Timo Korhonen via Tech-talk
enable pvAccess by default William Kirstaedter via Tech-talk
Re: enable pvAccess by default Johnson, Andrew N. via Tech-talk
Re: enable pvAccess by default William Kirstaedter via Tech-talk
Prev: Re: enable pvAccess by default Timo Korhonen via Tech-talk
Next: Re: enable pvAccess by default Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: enable pvAccess by default Timo Korhonen via Tech-talk
