1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: enable pvAccess by default
Date: Wed, 3 Apr 2024 11:25:13 -0700
Hi Michael,
Could you explain the difference between QSRV1 and QSRV2?
Or do we have any documentation which way we have to go to develop the pvacces support IOC?
Best,
Han
On Wed, Apr 3, 2024 at 10:37 AM Michael Davidsaver via Tech-talk <[email protected]> wrote:
On 3/31/24 13:53, William Kirstaedter via Tech-talk wrote:
> Hello Core Devs,
> I would like to know if you have already considered activating pvAccess for softIOCs by default.
Changing defaults seems certain to surprise someone.  I understand
the desire for change though as out of date defaults confuse new
users.
Historically, epics-base development has prioritized unsurprising
upgrades over unconfused newbies.  Still, changes are possible if
folks want to propose something concrete.  (aka. PRs welcomed)
> I would probably adapt the Makefile template and simply copy the section from the example IOC:
> # Link QSRV (pvAccess Server) if available
> ifdef EPICS_QSRV_MAJOR_VERSION
>      _APPNAME__LIBS += qsrv
>      _APPNAME__LIBS += $(EPICS_BASE_PVA_CORE_LIBS)
>      _APPNAME__DBD += PVAServerRegister.dbd
>      _APPNAME__DBD += qsrv.dbd
> endif
When PVXS is included in RELEASE, then PVXS_MAJOR_VERSION will be defined.
So some similar logic can be used.
> ifdef PVXS_MAJOR_VERSION
> _APPNAME__DBD += pvxsIoc.dbd
> _APPNAME__LIBS += pvxsIoc pvxs
> endif
Of course this raises the question of what to do if both are defined?
I have tried to design PVXS/QSRV2 so that both QSRV1 and QSRV2 can be linked
into the same executable.  In this happens, then on startup QSRV2 should
detect the presence of QSRV1 and disable itself.
That said, I would recommend avoiding this situation with Makefile logic like:
> ifdef PVXS_MAJOR_VERSION # prefer QSRV2 :)
> nasaAcq_DBD += pvxsIoc.dbd
> nasaAcq_LIBS += pvxsIoc pvxs
> else
> ifdef EPICS_QSRV_MAJOR_VERSION # fallback to QSRV1
> nasaAcq_LIBS += qsrv
> nasaAcq_LIBS += $(EPICS_BASE_PVA_CORE_LIBS)
> nasaAcq_DBD += PVAServerRegister.dbd
> nasaAcq_DBD += qsrv.dbd
> endif
> endif
Jeong Han Lee, Dr.rer.nat.
Lawrence Berkeley National Laboratory
Re: enable pvAccess by default Michael Davidsaver via Tech-talk
enable pvAccess by default William Kirstaedter via Tech-talk
Prev: Re: enable pvAccess by default Michael Davidsaver via Tech-talk
Next: Re: enable pvAccess by default Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
