On Thu, 4 Apr 2024 at 11:36, Abdalla Ahmad via Tech-talk <tech-talk at aps.anl.gov> wrote:
Stream and ASYN are unrelated. Have you updated iocStats, as Andrew suggested? That's the module that implements the exit record. BTW. Nothing happens, seems like the IOC shell is waiting for the “exit” to happen so I have to use Ctrl-C to force quit the IOC. I hope you are aware that in the iocShell, Ctrl-C is *not* the same as "exit". While "exit" or Ctrl-D (or the exit record) trigger an orderly shutdown that runs all registered exit hook routines, Ctrl-C stops the IOC immediately without running the exit hooks. Depending on your device drivers, there might be a noticeable difference between the two. Often, there is not. Cheers, ~Ralph
ANJ, 11 Sep 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
