1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Alarm Log Table
Date: Mon, 22 Apr 2024 16:35:02 +0000
Sir,
                I’m not sure if you resolved this, but I experienced a similar problem when attempting to set up alarm logging. Take a look at:
/phoebus/app/alarm/logging-ui/src/main/resources/alarm_logging_preferences.properties
I expect the service URI is set to http://localhost:9000
If you have maintained default setting for the alarm logger server, then the REST API is available on port 8080.
If you are running the alarm logger server and Phoebus on the same host, try changing the service URI:
service_uri = http://localhost:8080
You can also always netstat to see which port is listening for REST calls and update accordingly. If you have not adjusted default configs, then the above is probably your issue.
You can also verify that the alarm logger is presenting information by navigating to http://localhost:8080 in an internet browser (see https://github.com/ControlSystemStudio/phoebus/tree/master/services/alarm-logger)
V/R
Joshua West
Lower Colorado River Authority | Hydro Control Systems Administrator
O: 512-793-3054
[email protected]
Subject:
Alarm Log Table
saleem khan via Tech-talk <tech-talk at aps.anl.gov>
To:
Date:
Sat, 3 Feb 2024 07:09:57 +0500
SIr
i have problem in phoebus(phoebus-env) with alarm log table when i query for alarm log table Particularly the query string like this:
pv=*&severity=*&message=*&current_severity=*&current_message=*&user=*&host=*&command=*&start=7 days&end=now
then it find for searching and no response since a have already install elasticsearch 8
if any document or hints available???
Prev: AW: AW: Readback of output variables in adsDriver Meyer, Markus via Tech-talk
Next: Disable output record using asynInt32 interface automatic read from the hardware Yann Mandza via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Alarm Log Table saleem khan via Tech-talk
Next: EPICS on FPGA Abdalla Ahmad via Tech-talk
