1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Disable output record using asynInt32 interface automatic read from the hardware
From: Yann Mandza via Tech-talk <[email protected]>
Date: Mon, 22 Apr 2024 17:09:10 +0000
Hi all,
I have an asyn port driver using the asynInt32 and asynFloat64 interfaces for different output record types. Am using the asynDrvUser to create the driver parameters.
I noticed that for asynFloat64 interface, there is no auto call to the ‘readFloat64’ method when DB load at ioc boot which is the behaviour am expecting. However, for asynInt32 interface, Ao records tend to make a call to the ‘readInt32’ method somehow automatically. I tried longout and bo on that interface and there are no initial calls to ‘readInt32’.  Tried to follow this thread. https://epics.anl.gov/tech-talk/2019/msg01402.php, but am still puzzled on how to control this feature on AO records.
My DB looks somehow like this, am my driver has these asynflags: ASYN_CANBLOCK | ASYN_MULTIDEVICE
record( ao, "$(P)$(R):DelayedTripAction-O") {
      field(DTYP,"asynInt32")
      field(OUT,"@asyn($(PORT))INT_PARAM1($(ADDR))")
record(mbbo,"$(P)$(R):R2") {
        field(OUT,"@asyn($(PORT)) INT_PARAM2($(ADDR))")
Best Regards
Yann
RE: Disable output record using asynInt32 interface automatic read from the hardware Mark Rivers via Tech-talk
Prev: Re: Alarm Log Table Josh West via Tech-talk
Next: RE: Disable output record using asynInt32 interface automatic read from the hardware Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: behavior of PINI Di Wang via Tech-talk
