1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: Disable output record using asynInt32 interface automatic read from the hardware
To: Yann Mandza <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 22 Apr 2024 18:42:10 +0000
Hi Yann,
  • I noticed that for asynFloat64 interface, there is no auto call to the ‘readFloat64’ method when DB load at ioc boot which is the behaviour am expecting.
That does not seem correct to me.  The asynFloat64 device support for the ao record does do an initial read from the driver in this line:
https://github.com/epics-modules/asyn/blob/a94a78987a99b1c36bbd641a67341069dc5d627e/asyn/devEpics/devAsynFloat64.c#L623
What is your evidence that the readFloat64 method is not being called?
  • I tried longout and bo on that interface and there are no initial calls to ‘readInt32’.
Both of those records should make an initial call to readInt32.
The longout record is done in this line:
https://github.com/epics-modules/asyn/blob/a94a78987a99b1c36bbd641a67341069dc5d627e/asyn/devEpics/devAsynInt32.c#L1080
The bo record is done in this line:
https://github.com/epics-modules/asyn/blob/a94a78987a99b1c36bbd641a67341069dc5d627e/asyn/devEpics/devAsynInt32.c#L1184
The initial value read from the driver is only used in the record if the readFloat64 or readInt32 methods return asynSuccess.  Is your driver returning asynSuccess?
From: Tech-talk <[email protected]> On Behalf Of Yann Mandza via Tech-talk
Sent: Monday, April 22, 2024 12:09 PM
To: [email protected]
Subject: Disable output record using asynInt32 interface automatic read from the hardware
Hi all,
I have an asyn port driver using the asynInt32 and asynFloat64 interfaces for different output record types. Am using the asynDrvUser to create the driver parameters.
I noticed that for asynFloat64 interface, there is no auto call to the ‘readFloat64’ method when DB load at ioc boot which is the behaviour am expecting. However, for asynInt32 interface, Ao records tend to make a call to the ‘readInt32’ method somehow automatically. I tried longout and bo on that interface and there are no initial calls to ‘readInt32’.  Tried to follow this thread. https://epics.anl.gov/tech-talk/2019/msg01402.php, but am still puzzled on how to control this feature on AO records.
My DB looks somehow like this, am my driver has these asynflags: ASYN_CANBLOCK | ASYN_MULTIDEVICE
record( ao, "$(P)$(R):DelayedTripAction-O") {
      field(DTYP,"asynInt32")
      field(OUT,"@asyn($(PORT))INT_PARAM1($(ADDR))")
record(mbbo,"$(P)$(R):R2") {
        field(OUT,"@asyn($(PORT)) INT_PARAM2($(ADDR))")
Best Regards
Yann
Disable output record using asynInt32 interface automatic read from the hardware Yann Mandza via Tech-talk
Prev: Disable output record using asynInt32 interface automatic read from the hardware Yann Mandza via Tech-talk
Next: EPICS sometimes disconnect when I moving motor whitetiger1123 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
