The envPaths is to be created manually,
$ cd iocs/pylonIOC/iocBoot/iocPylon
$ make envPaths
On 4/30/24 12:57, Donny Domagoj Cosic via Tech-talk wrote:
Hello,
I successfully compiled AreaDetects R3-13 and added the ADPylon option into the config file with the path to the Pylon SDK (v7.4.0). The ADPylon module was created and I followed the instructions for reading the XML file from a Basler Camera and created the db and adl files using ADGenICam.
I modified the st.cmd file in the ADPylon IOC with the address of the camera I want to connect to but when I run the st.cmd file I noticed that the envPaths file is missing from the folder.
Do I have to separately compile the ADPylon IOC? If I try this, I get an error that I am missing the Pylon library even though the path is defined to "/opt/pylon/". Could this be because I am using a newer version of Pylon SDK? Which version has been tested with this IOC?
Additionally, after I start the IOC, how can I display the video from the camera in CS-Studio Pheobus?
Thank you in advance,
- AreaDetectors - ADPylon Donny Domagoj Cosic via Tech-talk
Re: AreaDetectors - ADPylon Jörn Dreyer via Tech-talk
<2024>
<2024>
