1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: AreaDetectors - ADPylon
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: Ralph Lange via Tech-talk <[email protected]>
Date: Tue, 30 Apr 2024 12:57:28 +0200
Hello,
I successfully compiled AreaDetects R3-13 and added the ADPylon option into the config file with the path to the Pylon SDK (v7.4.0). The ADPylon module was created and I followed the instructions for reading the XML file from a Basler Camera and created the db and adl files using ADGenICam. I modified the st.cmd file in the ADPylon IOC with the address of the camera I want to connect to but when I run the st.cmd file I noticed that the envPaths file is missing from the folder.
Do I have to separately compile the ADPylon IOC? If I try this, I get an error that I am missing the Pylon library even though the path is defined to "/opt/pylon/". Could this be because I am using a newer version of Pylon SDK? Which version has been tested with this IOC?
Additionally, after I start the IOC, how can I display the video from the camera in CS-Studio Pheobus?
Thank you in advance,
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: [email protected] | https://urldefense.us/v3/__http://www.irb.hr__;!!G_uCfscf7eWS!awxZd8NQygTXOqUSZfkGWCcBIzltGfzJzeBXzaEhYN5KzDzwdPNTaBcy_HC02DLAb-Vf9jhfrcIKiAktbbwBIwOdaZ7E8kfZ$
Re: AreaDetectors - ADPylon Wang Xiaoqiang via Tech-talk
Re: AreaDetectors - ADPylon Jörn Dreyer via Tech-talk
Prev: Using PyAT Abdalla Ahmad via Tech-talk
Next: Re: AreaDetectors - ADPylon Wang Xiaoqiang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: RE: Using PyAT Blomley, Edmund (IBPT) via Tech-talk
