1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: difference between DB and DB_INSTALLS
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 13 May 2024 17:23:20 +0200
On Mon, 13 May 2024 at 15:59, William Kirstaedter via Tech-talk <[email protected]> wrote:
short question regarding EPICS' build system ...:
whats the difference between DB += myfile.db and DB_INSTALLS += myfile.db ?
Generally:
    generate *.db using a large and complex set of rules
vs.
    just install a file
DB_INSTALLS is typically used to install Stream protocol files or Access configuration files or ...
anything where applying the *.db generation rules would create havoc.
Cheers,
~Ralph
Re: difference between DB and DB_INSTALLS Johnson, Andrew N. via Tech-talk
difference between DB and DB_INSTALLS William Kirstaedter via Tech-talk
Prev: difference between DB and DB_INSTALLS William Kirstaedter via Tech-talk
Next: Re: 4 instances vs 1 instance of Tomcat for ArchiverAppliance Shankar, Murali via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: difference between DB and DB_INSTALLS Johnson, Andrew N. via Tech-talk
