1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: 4 instances vs 1 instance of Tomcat for ArchiverAppliance
From: "Shankar, Murali via Tech-talk" <[email protected]>
Date: Mon, 13 May 2024 15:48:28 +0000
Re: Does it have something to do with reliability?
Yes. Originally, we were using JCA to talk to EPICS PVS and that would core dump occasionally. And we really do NOT want the ETL workflows to be interrupted abruptly. This has since changed in that we use the Java versions of the EPICS libraries and those are quite stable these days.
Also, the workloads are quite different between the components and separating them out may be less burdensome on GC.
It is also sometimes useful to have the ability to just restart one component  - like the retrieval component which can sometimes get into a death spiral of full GC.
Hope that helps.
Murali
Prev: Re: difference between DB and DB_INSTALLS Ralph Lange via Tech-talk
Next: Re: difference between DB and DB_INSTALLS Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: 4 instances vs 1 instance of Tomcat for ArchiverAppliance NICOLE Remi via Tech-talk
Next: difference between DB and DB_INSTALLS William Kirstaedter via Tech-talk
