> if the initial status of the PV is already disconnected
Each PV starts out in the disconnected state.
Ideally, it will then connect “real soon” and you get the first value update, but if you never hear anything, that means it was and remains disconnected.
-Kay
Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Wang, Lin via Tech-talk <tech-talk at aps.anl.gov>
Date: Thursday, May 16, 2024 at 11:29 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] How to check if a PV is initially disconnected using org.phoebus.pv.PV.onValueEvent().subscribe()
Dear all,
When monitoring a PV using the following Java code snippet, if the status of the PV changes from connected to disconnected, valueChanged() will be invoked and the disconnected status can be checked. However, if the initial
status of the PV is already disconnected, then valueChanged() will not be invoked, thus I do not know if the PV is disconnected or "connected but has no new value".
import
org.epics.vtype.VType;
import
org.phoebus.pv.PV;
import
org.phoebus.pv.PVPool;
import
io.reactivex.rxjava3.disposables.Disposable;
public
void
start()
throws
Exception
PV
pv
PVPool.getPV("test:123");
Disposable
pv_flow
pv.onValueEvent().subscribe(this::valueChanged);
private
void
valueChanged(final
VType
value)
if (PV.isDisconnected(value))
System.out.println("PV
is disconnected");
How can I check if the PV is initially disconnected or is not available at all using this monitoring approach?
Lin
- How to check if a PV is initially disconnected using org.phoebus.pv.PV.onValueEvent().subscribe() Wang, Lin via Tech-talk
XSPRESS3 error messages John Dobbins via Tech-talk
Re: XSPRESS3 error messages Matthew Newville via Tech-talk
<2024>
<2024>
ANJ, 11 Sep 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
