1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: XSPRESS3 error messages
From: Matthew Newville via Tech-talk <[email protected]>
To: John Dobbins <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 16 May 2024 16:07:09 +0000
Hi John,
Hm, that does seem like it is from the hardware.  Are you pointing to the same xps3 settings files with both IOC versions?
I sometimes find that just removing all of the xsp* files in /dev/shm helps, especially if the setup or calibration changes. These files will be recreated on restart.
Matt
--Matt
From: Tech-talk <[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
Sent: Thursday, May 16, 2024 10:35:18 AM
To: [email protected] <[email protected]>
Subject: XSPRESS3 error messages
All,
I don't think this is an EPICS issue but I am asking in case anyone might have related experience.
We have a four channel XSPRESS3, which is 10+ year old.  This has the older hardware format in which a single card hosts up to 8 channels.  This past January I updated the IOC from the original IOC to
the build_xspress3.py script at the time called out
'xspress3': 'xspress3-2-4.tar.gz'
which is see has since been updates to
'xspress3': 'xspress3-2-8.tar.gz'
The new IOC runs, though the data is sporadically noisier than with the old IOC. Also, we get error messages at the IOC console like:
epics> Received data from wrong channel = 0 at path=0, card=0, chan_of_card=3
ERROR: Received end of frame marker from chan=2. old frame=158 but count=13, not
2 WHY?
Received data from wrong channel = 1 at path=0, card=0, chan_of_card=0
Received data from wrong channel = 0 at path=0, card=0, chan_of_card=1
Received data from wrong channel = 2 at path=0, card=0, chan_of_card=0
Received data from wrong channel = 1 at path=0, card=0, chan_of_card=2
Received data from wrong channel = 3 at path=0, card=0, chan_of_card=0
Received data from wrong channel = 1 at path=0, card=0, chan_of_card=3
**** TOO MANY WRONG CHAN WARNINGS disabling printing***
Received data from wrong channel = 3 at path=0, card=0, chan_of_card=2
Received data from wrong channel = 3 at path=0, card=0, chan_of_card=1
ERROR: Received end of frame marker from chan=0. old frame=160 but count=13, not
2 WHY?
ERROR: Received end of frame marker from chan=0. old frame=167 but count=13, not
2 WHY?
ERROR: Received end of frame marker from chan=1. old frame=176 but count=1010, n
ot 2 WHY?
I see that the messages come from the xspress3 library and not the EPICS source code.
Regards, any help appreciated.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
XSPRESS3 error messages John Dobbins via Tech-talk
Prev: Re: [EXTERNAL] How to check if a PV is initially disconnected using org.phoebus.pv.PV.onValueEvent().subscribe() Kasemir, Kay via Tech-talk
Next: Re: urldefense.us URLs? Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: XSPRESS3 error messages John Dobbins via Tech-talk
Next: EPICS and EPICS+PVXS internal threading of IOCs Dave Bracey via Tech-talk
