1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Changing runtime limits with Channel Access
From: Alessandra Palazzo via Tech-talk <[email protected]>
Date: Fri, 17 May 2024 12:43:08 +0000
Hello all,
I am using CS-Studio Phoebus (version 4.7.3) with Epics (version 7.0.8).
I am having issues with changing runtime limits with Channel Access.
I have an ao record that I want to use as upper limit for other ao records through a dfanout one.
If I monitor these upper limits I see them changing when I change the first ao record, but they are not propagated to the spinners controlling the other PVs.
I set the dbe_property_supported to True in the Phoebus settings but this didn't help.
Is there anything wrong with what I'm doing?
Alessandra
Alessandra Palazzo
Control System Engineer
Present: Mon - Tue - Wed - Thu - Fri
High Voltage Engineering Europa B.V.
Amsterdamseweg 63, 3812 RR Amersfoort
P.O. Box 99, 3800 AB Amersfoort, The Netherlands
Tel       +31334619741
Fax      +31334615291
E-mail  [email protected]
Web     www.highvolteng.com
Re: Changing runtime limits with Channel Access Ulrik Pedersen via Tech-talk
Prev: ADUrl and digest authentication Tomasz Brys via Tech-talk
Next: Re: urldefense.us URLs? Kevin Peterson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: ADUrl and digest authentication Heesterman, Peter via Tech-talk
Next: Re: Changing runtime limits with Channel Access Ulrik Pedersen via Tech-talk
