1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: Changing runtime limits with Channel Access
From: Ulrik Pedersen via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 20 May 2024 11:37:23 +0100
Hi Alessandra,
Please could you post here the snippet of the database logic showing the records involved in setting these limits? Its not clear from your message which fields you are using. You should be using the HOPR and LOPR fields as described in the "Operator Display Parameters" in the ao record docs.
It may also be useful if you post the relevant snippet of your Phoebus configuration file where you set the dbe_property_supported configuration parameter.
Cheers,
Ulrik
Ulrik Pedersen
Observatory Sciences Ltd.
Rutherford Appleton Laboratory
Building R104, 1-09
Harwell Campus, Didcot, OX11 0QX
Phone: 01223 655 603
On Fri, 17 May 2024 at 13:43, Alessandra Palazzo via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hello all,
I am using CS-Studio Phoebus (version 4.7.3) with Epics (version 7.0.8).
I am having issues with changing runtime limits with Channel Access.
I have an ao record that I want to use as upper limit for other ao records through a dfanout one.
If I monitor these upper limits I see them changing when I change the first ao record, but they are not propagated to the spinners controlling the other PVs.
I set the dbe_property_supported to True in the Phoebus settings but this didn't help.
Is there anything wrong with what I'm doing?
Alessandra
Alessandra Palazzo
Control System Engineer
Present: Mon - Tue - Wed - Thu - Fri
High Voltage Engineering Europa B.V.
Amsterdamseweg 63, 3812 RR Amersfoort
P.O. Box 99, 3800 AB Amersfoort, The Netherlands
Tel       +31334619741
Fax      +31334615291
E-mail  apalazzo at highvolteng.com
Web     www.highvolteng.com
Re: Changing runtime limits with Channel Access Ralph Lange via Tech-talk
Changing runtime limits with Channel Access Alessandra Palazzo via Tech-talk
Prev: Re: difference between DB and DB_INSTALLS Ralph Lange via Tech-talk
Next: Re: Changing runtime limits with Channel Access Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Changing runtime limits with Channel Access Alessandra Palazzo via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
