1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: difference between DB and DB_INSTALLS
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Sun, 19 May 2024 17:40:42 +0200
On Sat, 18 May 2024 at 20:02, Michael Davidsaver <[email protected]> wrote:
On 5/13/24 12:37, Johnson, Andrew N. via Tech-talk wrote:
> IIRC the original build rules for DB_INSTALLS allow the source path to point into a support module or other external directory, whereas the DB rules were designed for generating and copying files from the local application only. Thus you can use DB_INSTALLS += $(ASYN)/db/asynRecord.dbto copy that file from your Asyn module into the IOC's $(TOP)/dbdirectory.
... so that an iocsh script need only read files from "$(TOP)/db".
I see this as an important complement to static linking of IOC executables.
Both act to "isolate" an IOC instance from changes to files elsewhere in
the system.  Hopefully avoiding a situation where an unplanned IOC restart
picks up unexpected changes.
It's a design choice, in the end.
This isolation is appropriate for the "self-containing" approach, while in our RPM-based deployment system I *want* global files (libraries as well as db files) to be picked up by IOCs, so that after deploying a new version of one of our shared support modules - containing both shared library and the matching db files - we don't have to recompile and repackage all IOCs. (As long as the APIs - the library API and the line in the startup script - are stable.)
Cheers,
~Ralph
difference between DB and DB_INSTALLS William Kirstaedter via Tech-talk
Re: difference between DB and DB_INSTALLS Ralph Lange via Tech-talk
Re: difference between DB and DB_INSTALLS Johnson, Andrew N. via Tech-talk
Re: difference between DB and DB_INSTALLS Michael Davidsaver via Tech-talk
Prev: RE: Magna Power TS Abdalla Ahmad via Tech-talk
Next: Re: Changing runtime limits with Channel Access Ulrik Pedersen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: difference between DB and DB_INSTALLS Michael Davidsaver via Tech-talk
Next: Magna Power TS Zumbruch, Peter Dr. via Tech-talk
