1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: EPICS module/service that can be used for saving waveform data/metadata to HDF5
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
Date: Tue, 11 Jun 2024 13:22:02 +0000
Hi all,
During the EPICS codeathon this week at NSLS-II I mentioned a need for us here at NSLS-II w.r.t. data saving. Essentially, we are beginning to work on hardening the data access security for scientific data, one consequence of this being that operator accounts that users run their experiments under will no longer have r/w access to data directories, and all data needs to be written by either a softioc service account, or by a workflow service account.
The problem with this, is that for a fair number of detectors/devices that did not have any in-built file saving capabilities (basically anything that isn't an areaDetector driver), the previous approach was to basically caget​ the waveform data and any metadata signals, and in the bluesky experiment orchestration layer use the h5py library to save the data, all as this operator account. Since this approach will no longer work due to the new permissions, to work around this, we've been moving this code into python IOCs that expose some PVs that are then used to more or less call the same functions from bluesky - just now with the file saving done as a softioc account. However, I don't think this is an ideal solution - it is leading to a lot of one-off IOCs for each of these devices.
I've been thinking of ways to build something more general that will allow for specifying a waveform record and some additional metadata and saving it when asked, and it was suggested to me at the codeathon to reach out here to the community to see if others have a similar need or ideas on how to handle this.
Thanks!
Jakub
RE: EPICS module/service that can be used for saving waveform data/metadata to HDF5 Pearson, Matthew via Tech-talk
Prev: RE: epics build system question again - build order Freddie Akeroyd - STFC UKRI via Tech-talk
Next: RE: EPICS module/service that can be used for saving waveform data/metadata to HDF5 Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: RE: automatically start the IOC via procServ Mark Rivers via Tech-talk
