1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: automatically start the IOC via procServ
To: 周逸媚 <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 11 Jun 2024 17:01:54 +0000
  • Each time the processor is turned on, the PVs is 0 for all outputs.
What do you mean by “the processor is turned on”?  Is something power-cycled, or are you just starting the IOC?
Please send the complete output when the IOC is first started with procServ and is not working correctly.
From: Tech-talk <[email protected]> On Behalf Of ??? via Tech-talk
Sent: Tuesday, June 11, 2024 2:19 AM
To: [email protected]
Subject: automatically start the IOC via procServ
Dear, sir
I have a question about procServ starting an IOC.
When I run the IOC through ../../bin/linux-arm/SHINE st.cmd
all pvs run normally and output the correct results.
Then, I automatically start the IOC via procServ.
These pv variables are in ai or longin form and are output via setDoubleParam or setIntegerParam.
in SHINE.db:
record(ai, "$(P)$(R)BPM_X")
   field(DTYP, "asynFloat64")
   field(INP,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))BPM_X")
   field(SCAN, "I/O Intr")
in SHINE.cpp
setDoubleParam(P_BPM_X,        (signed)bpm_x/1000.00);
callParamCallbacks();
or waveforms
record(waveform, "$(P)$(R)CH1_RAW_WAVEFORM")
    field(DTYP, "asynFloat64ArrayIn")
    field(INP,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))CH1_RAW_WAVEFORM")
    field(FTVL, "DOUBLE")
    field(NELM, "2048")
doCallbacksFloat64Array(pData_CH1_waveform, imglen, P_CH1_Waveform, 0);
When I check the PVs,they show <undefined> 0 UDF INVALID
root@snk2-debian-project:~# telnet localhost 20001
Trying ::1...
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
@@@ Welcome to procServ (procServ Process Server 2.7.0)
@@@ Use ^X to kill the child, auto restart is ON, use ^T to toggle auto restart
@@@ procServ server PID: 356
@@@ Server startup directory: /home/EPICS/SHINE-IOC/iocBoot/iocSHINE
@@@ Child startup directory: /home/EPICS/SHINE-IOC/iocBoot/iocSHINE
@@@ Child "SHINE-IOC" started as: ./st.cmd
@@@ Child "SHINE-IOC" PID: 363
@@@ procServ server started at: Wed Jun  5 13:13:59 2024
@@@ Child "SHINE-IOC" started at: Wed Jun  5 13:13:59 2024
@@@ 0 user(s) and 0 logger(s) connected (plus you)
dbpr SHINE-BI:BPM_X
AMSG:               ASG :               DESC:               DISA: 0
DISV: 1             NAME: SHINE-BI:BPM_X                    NAMSG:
RVAL: 0             SEVR: INVALID       STAT: UDF           SVAL: 0
TPRO: 0             VAL : 0
However,if I restart the IOC, they show up fine.
epics> ^C@@@ Current time: Wed Jun  5 13:18:57 2024
@@@ Child process is shutting down, a new one will be restarted shortly
@@@ ^R or ^X restarts the child, ^Q quits the server
@@@ Received a sigChild for process 363. The process was killed by signal 2
@@@ Restarting child "SHINE-IOC"
@@@    (as ./st.cmd)
@@@ The PID of new child "SHINE-IOC" is: 443
#!../../bin/linux-arm/SHINE
< envPaths
epicsEnvSet("IOC","iocSHINE")
epicsEnvSet("TOP","/home/EPICS/SHINE-IOC")
epicsEnvSet("EPICS_BASE","/home/EPICS/base-7.0.7")
epicsEnvSet("SUPPORT","/home/EPICS/support")
epicsEnvSet("ASYN","/home/EPICS/support/asyn4-38")
epicsEnvSet("AUTOSAVE","/home/EPICS/support/autosave-R5-10-2")
cd "/home/EPICS/SHINE-IOC"
dbLoadDatabase "dbd/SHINE.dbd"
SHINE_registerRecordDeviceDriver pdbbase
## Load record instances
#dbLoadTemplate "db/user.substitutions"
#dbLoadRecords "db/SHINEVersion.db", "user=root"
#dbLoadRecords "db/dbSubExample.db", "user=root"
##### ZYM ###########
SHINEConfigure("testAPD", 1000)
#############mode_type = 2
################# mmap finished ##################
------------pre_value_ddr=30100000
################# value setting finished ##################
dbLoadRecords("db/SHINE.db","P=SHINE-BI:,R=,PORT=testAPD,ADDR=0,TIMEOUT=10000")
#dbLoadRecords("db/asynRecord.db","P=SHINE-BI:,R=,PORT=testAPD,ADDR=0,OMAX=,IMAX=")
########## AUTOSAVE ##########
set_requestfile_path(".")
set_savefile_path("/home/EPICS/","autosave")
save_restoreSet_IncompleteSetsOk(1)
save_restoreSet_DatedBackupFiles(0)
set_pass0_restoreFile("shineioc.sav")
cd "/home/EPICS/SHINE-IOC/iocBoot/iocSHINE"
iocInit
Starting iocInit
## EPICS R7.0.7
## Rev. 2023-04-11T16:40+0800
## Rev. Date build date/time:
reboot_restore: entry for file 'shineioc.sav'
reboot_restore: Found filename 'shineioc.sav' in restoreFileList.
*** restoring from '/home/EPICS/autosave/shineioc.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'shineioc.sav'
create_monitor_set("shineioc.req",10,"P=SHINE-BI:")
------------value_ddr=7010000a
## Start any sequence programs
#seq sncExample, "user=root"
epics> shineioc.sav: 38 of 38 PV's connected
dbpr SHINE-BI:BPM_X
RVAL: 0             SEVR: NO_ALARM      STAT: NO_ALARM      SVAL: 0
TPRO: 0             VAL : -3739.613
The autostart service is
[Unit]
Description=Start EPICS IOC for asyn port driver
After=network.target
[Service]
Type=forking
Restart=on-failure
RestartSec=5
ExecStart=/home/EPICS/runioc.sh
ExecReload=/bin/kill -s HUP $MAINPID
ExecStop=/bin/kill -s TERM $MAINPID
ExecStopPost=/usr/bin/sleep 5
TimeoutStopSec=5
User=root
[Install]
WantedBy=multi-user.target
The runioc.sh is:
#!/bin/bash
export EPICS_CA_MAX_ARRAY_BYTES=50000000
cd /home/EPICS/SHINE-IOC/iocBoot/iocSHINE
procServ -n "SHINE-IOC" -I ^D^C 20001 ./st.cmd
Best regards,
Yimei Zhou
automatically start the IOC via procServ 周逸媚 via Tech-talk
Prev: A Tribute to Professor LIU Songqiang Hu, Yong via Tech-talk
Next: web-pvtools: PV client tools for web Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: automatically start the IOC via procServ 周逸媚 via Tech-talk
Next: EPICS module/service that can be used for saving waveform data/metadata to HDF5 Wlodek, Jakub via Tech-talk
