1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: AreaDetector Pva problem
From: Jörn Dreyer via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 17 Jun 2024 13:39:50 +0200
Hi all,
I have a problem with EPICS 7.0.8 when trying to retrieve image data from an areaDetector using the pva protocol.
I'm using the Pva plugin because of the size of the image (61 Mpixels). The PV is "cam:Pva1:Image" and in my program
using pvAccess I get the following error:
Error: PvaClientData::getDoubleArray() did not find a scalarArray field
When doing the following:
pva = PvaClient::get("pva ca");
PvaClientChannelPtr channel = pva->channel("cam:Pva1:Image", "pva", 2.0);
epics::pvData::shared_vector<const double> array = channel->getDoubleArray();
Enabling debugging for pva gives the following:
PvaClientChannel::PvaClientChannel channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
PvaClientChannel::connect channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
PvaClientChannel::issueConnect channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
PvaClientChannel::issueConnect calling provider->createChannel
PvaClientChannel::channelCreated channelName WIZZLERHD:HZDR:asicam1:Pva1:Image connectState 1 isConnected false status.isOK true
PvaClientChannel::waitConnect channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
 PvaClientChannel::channelStateChange  channelName WIZZLERHD:HZDR:asicam1:Pva1:Image CONNECTED
PvaClientGet::create(pvaClient,channelName,pvRequest)
 channelName WIZZLERHD:HZDR:asicam1:Pva1:Image pvRequest structure
    structure field
        structure value
PvaClientGet::PvaClientGet channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
PvaClientGet::connect channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
PvaClientGet::issueConnect channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
PvaClientGet::waitConnect channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
PvaClientGet::channelGetConnect channelName WIZZLERHD:HZDR:asicam1:Pva1:Image status.isOK true
PvaClientGetData::create
PvaClientGet::get channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
PvaClientGet::issueGet channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
PvaClientGet::waitGet channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
PvaClientGet::getDone channelName WIZZLERHD:HZDR:asicam1:Pva1:Image status.isOK true
PvaClientData::setData
PvaClientGet::getData  channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
PvaClientGet::checkConnectState channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
PvaClientData::getSinglePVField
The array vaiable is 0 in this case.
No clue what I am doing wrong here?
I can retrieve the value of the pv with pvget. So it exists and is correctly filled.
Any help appreciated!
Regards
Jörn
Re: AreaDetector Pva problem Jörn Dreyer via Tech-talk
Prev: Re: New EPICS Archiver Appliance Documentation Site Timo Korhonen via Tech-talk
Next: Building EPICS 7 John Dong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Next: Re: AreaDetector Pva problem Jörn Dreyer via Tech-talk
