1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: AreaDetector Pva problem
From: Jörn Dreyer via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 19 Jun 2024 14:14:04 +0200
Hi all,,
after some more investigation it turned out the the problem was an not handled error situation in which the PV did not return a valid array.
This now leaves me with the question how the data is organized in the case of the Pva plugin versus the standard NDArray data.
Where can I find some detailed information about that?
Regards
Jörn
Am Montag, 17. Juni 2024, 13:39:50 MESZ schrieb Jörn Dreyer via Tech-talk:
> Hi all,
> I have a problem with EPICS 7.0.8 when trying to retrieve image data from an areaDetector using the pva protocol.
> I'm using the Pva plugin because of the size of the image (61 Mpixels). The PV is "cam:Pva1:Image" and in my program
> using pvAccess I get the following error:
> Error: PvaClientData::getDoubleArray() did not find a scalarArray field
> When doing the following:
> pva = PvaClient::get("pva ca");
> PvaClientChannelPtr channel = pva->channel("cam:Pva1:Image", "pva", 2.0);
> epics::pvData::shared_vector<const double> array = channel->getDoubleArray();
> Enabling debugging for pva gives the following:
> PvaClientChannel::PvaClientChannel channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
> PvaClientChannel::connect channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
> PvaClientChannel::issueConnect channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
> PvaClientChannel::issueConnect calling provider->createChannel
> PvaClientChannel::channelCreated channelName WIZZLERHD:HZDR:asicam1:Pva1:Image connectState 1 isConnected false status.isOK true
> PvaClientChannel::waitConnect channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
>  PvaClientChannel::channelStateChange  channelName WIZZLERHD:HZDR:asicam1:Pva1:Image CONNECTED
> PvaClientGet::create(pvaClient,channelName,pvRequest)
>  channelName WIZZLERHD:HZDR:asicam1:Pva1:Image pvRequest structure
>     structure field
>         structure value
> PvaClientGet::PvaClientGet channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
> PvaClientGet::connect channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
> PvaClientGet::issueConnect channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
> PvaClientGet::waitConnect channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
> PvaClientGet::channelGetConnect channelName WIZZLERHD:HZDR:asicam1:Pva1:Image status.isOK true
> PvaClientGetData::create
> PvaClientGet::get channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
> PvaClientGet::issueGet channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
> PvaClientGet::waitGet channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
> PvaClientGet::getDone channelName WIZZLERHD:HZDR:asicam1:Pva1:Image status.isOK true
> PvaClientData::setData
> PvaClientGet::getData  channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
> PvaClientGet::checkConnectState channelName WIZZLERHD:HZDR:asicam1:Pva1:Image
> PvaClientData::getSinglePVField
> The array vaiable is 0 in this case.
> No clue what I am doing wrong here?
> I can retrieve the value of the pv with pvget. So it exists and is correctly filled.
> Any help appreciated!
> Regards
> Jörn
Re: AreaDetector Pva problem Mark Rivers via Tech-talk
AreaDetector Pva problem Jörn Dreyer via Tech-talk
Prev: Re: Strange problem with EPICS areaDetector Jörn Dreyer via Tech-talk
Next: Re: Strange problem with EPICS areaDetector Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: AreaDetector Pva problem Jörn Dreyer via Tech-talk
Next: Re: AreaDetector Pva problem Mark Rivers via Tech-talk
