1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: RE: [External] RE: Building EPICS 7
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
To: 'John Dong' <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 18 Jun 2024 10:42:46 +0000
Can you check that your   EPICS_HOST_ARCH   environment variable is set to      windows-x64-mingw        it looks from this that the EPICS build system  is trying to build using the visual studio rather than mingw compiler
Freddie
Sent: Tuesday, June 18, 2024 11:28 AM
To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>
Subject: Re: [External] RE: Building EPICS 7
Hi Freddie,
I am using Strawberry Perl so I built with mingw.
This is the error:
 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         -c ../flex/ccl.c
process_begin: CreateProcess(NULL, cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include -c ../flex/ccl.c, ...) failed.
make (e=2): The system cannot find the file specified.
gmake[4]: *** No rule to make target 'ccl.obj', needed by 'e_flex.exe'.  Stop.
gmake[4]: Leaving directory 'C:/EPICS/epics-base/modules/libcom/src/O.windows-x64'
gmake[3]: *** [../../../configure/RULES_ARCHS:58: install.windows-x64] Error 2
gmake[3]: Leaving directory 'C:/EPICS/epics-base/modules/libcom/src'
gmake[2]: *** [../../configure/RULES_DIRS:85: src.install] Error 2
gmake[2]: Leaving directory 'C:/EPICS/epics-base/modules/libcom'
gmake[1]: *** [../configure/RULES_DIRS:85: libcom.install] Error 2
gmake[1]: Leaving directory 'C:/EPICS/epics-base/modules'
gmake: *** [configure/RULES_DIRS:85: modules.install] Error 2
John Dong/PPPL
On Mon, Jun 17, 2024 at 6:51PM Freddie Akeroyd - STFC UKRI <[email protected]> wrote:
Hi, are you building with visual studio or mingw? I’ve seen this error before when building with visual studio and the compiler (cl.exe) is not found in the windows PATH,  it might be the same can  occur with mingw if it can’t locate the compiler either. Could you please post the output of your build showing the error message and lines of output displayed on screen prior to the error
Freddie
From: Tech-talk <[email protected]> On Behalf Of John Dong via Tech-talk
Sent: Monday, June 17, 2024 5:44 PM
To: EPICS Tech-Talk <[email protected]>
Subject: Building EPICS 7
I encountered the missing CCL.OBJ error when building epics-base. The problem still exists with the current version of Strawberry Perl.
John Dong/Princeton Plasma Physics Lab
Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj)
Andrew Johnson via Core-talk <[email protected]>
@Ralph  I see this is using an older ActiveState Perl, is that configurable somehow? The latest StrawberryPerl packages (available through Chocolatey) install GNU Make-4.2.1 (named "gmake") and gcc as well, so they provide everything we need for a MinGW build. That's what I'm using here and had no problems with.
Building EPICS 7 John Dong via Tech-talk
RE: Building EPICS 7 Freddie Akeroyd - STFC UKRI via Tech-talk
Re: [External] RE: Building EPICS 7 John Dong via Tech-talk
Prev: Re: [External] RE: Building EPICS 7 Ralph Lange via Tech-talk
Next: Re: [External] RE: Building EPICS 7 John Dong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: [External] RE: Building EPICS 7 Hu, Yong via Tech-talk
Next: Strange problem with EPICS areaDetector Jörn Dreyer via Tech-talk
