Subject: |
Re: [External] RE: Building EPICS 7 |
John Dong via Tech-talk <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Tue, 18 Jun 2024 06:47:46 -0400 |
Guys,
I want to thank you for your quick assistance. The last EPICS build I did was before 2000.
jd
Hi Ralph,
My environment variables:
I was following the attached instructions. I will try the one you suggested.
jd
I am using Strawberry Perl so I built with mingw.
This is the error: ... process_begin: CreateProcess(NULL, cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I../osi/compiler/msvc -
That's the command line for the Microsoft compiler (MSVC). Your EPICS_HOST_ARCH seems to be configured for the wrong toolchain.
Do you have any particular reason to not follow the Windows instructions at
Cheers, ~Ralph
- Building EPICS 7 John Dong via Tech-talk
- RE: Building EPICS 7 Freddie Akeroyd - STFC UKRI via Tech-talk
- Re: [External] RE: Building EPICS 7 John Dong via Tech-talk
- Re: [External] RE: Building EPICS 7 Ralph Lange via Tech-talk
RE: [External] RE: Building EPICS 7 Freddie Akeroyd - STFC UKRI via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
