1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Archiver Appliance PV by Policy
From: Paul Sichta via Tech-talk <[email protected]>
To: Sky Brewer <[email protected]>
Date: Wed, 26 Jun 2024 11:14:50 -0400
Thanks Sky,  that showed the policyName for the PV and should help me get the policyName displayed in a table or report.
-ps
On Wed, Jun 26, 2024 at 3:40 AM Sky Brewer via Tech-talk <[email protected]> wrote:
You probably want to use the endpoint getPVTypeInfo, for example calling
http://archiver_host_name:17665/mgmt/bpl/getPVTypeInfo?pv=PV1
Will get you json including “policyName”, “datastores”, “samplingPeriod” and “samplingMethod”
The PVTypeInfo is essentially what is stored in the persistence database.
Hope that helps!
Sky
RE: Archiver Appliance PV by Policy Sky Brewer via Tech-talk
Prev: Re: mbbo fields don't match db definitions ??? John Dobbins via Tech-talk
Next: Re: install epics-base: Perl Script Path Interpretation Issue on Windows Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: RE: Archiver Appliance PV by Policy Sky Brewer via Tech-talk
Next: CSS-Phoebus: Dynamically changing the contents of embedded databrowser Malte Daniel Gotz via Tech-talk
