1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: install epics-base: Perl Script Path Interpretation Issue on Windows
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Hussein Matar <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 26 Jun 2024 15:25:55 +0000
Hi Hussein,
Unfortunately the EPICS build rules and our Makefiles don't work when the path to Base or other modules contain spaces, and it would be quite a lot of work to fix that (patches welcome if it's important to you!). You can't just change a configuration setting to get around that.
Thank-you for posting the complete error messages. It looks like you have Base installed inside a MS Visual Studio BuildTools subdirectory. That is not a good location, I recommend that you build it somewhere like C:\epics\base. In addition to Base you will be installing and building other support modules such as Asyn, so that layout lets you use C:\epics\asyn for that, and so on.
Hope this helps,
- Andrew
On 6/26/24, 9:26 AM, "Tech-talk" <[email protected]> wrote:
Hello,
I am setting up EPICS Base on my Windows 10 machine, but I get a compile
error when I run the Makefile in the EPICS Base directory:
perl -CSD C:/Program Files (x86)/Microsoft Visual
Studio/2022/BuildTools/epics-base
/bin/windows-x64/makeMakefile.pl
O.windows-x64 ../../../..
Can't open perl script "C:/Program": No such file or directory
It seems that my compiler does not interpret the path to the Perl script
correctly, as it only captures the path up to the first space. As a
result, the Perl script cannot be found.
Can you tell me why this is happening and how I can fix the problem?
Which configuration file do I need to edit to correct this?
The complete output of the makefile:
make
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C
./configure install
make[1]: Entering directory 'C:/Program Files (x86)/Microsoft Visual
Studio/2022/BuildTools/epics-base/configure'
O.windows-x64 -f ../Makefile TOP=../.. \
     T_A=windows-x64 install
make[2]: Entering directory 'C:/Program Files (x86)/Microsoft Visual
Studio/2022/BuildTools/epics-base/configure/O.windows-x64'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory 'C:/Program Files (x86)/Microsoft Visual
make[1]: Leaving directory 'C:/Program Files (x86)/Microsoft Visual
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./src
install
Studio/2022/BuildTools/epics-base/src'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./tools
install
Studio/2022/BuildTools/epics-base/src/tools'
O.windows-x64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'C:/Program Files (x86)/Microsoft Visual
Studio/2022/BuildTools/epics-base/src/tools/O.windows-x64'
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory 'C:/Program Files (x86)/Microsoft Visual
template/base install
Studio/2022/BuildTools/epics-base/src/template/base'
Studio/2022/BuildTools/epics-base/bin/windows-x64/makeMakefile.pl
make[2]: *** [../../../configure/RULES_ARCHS:67: O.windows-x64] Error 2
make[1]: *** [../configure/RULES_DIRS:85: template/base.install] Error 2
make: *** [configure/RULES_DIRS:85: src.install] Error 2
Thanks
Hussein
Re: install epics-base: Perl Script Path Interpretation Issue on Windows Ralph Lange via Tech-talk
install epics-base: Perl Script Path Interpretation Issue on Windows Hussein Matar via Tech-talk
Prev: Re: Archiver Appliance PV by Policy Paul Sichta via Tech-talk
Next: Re: CSS-Phoebus: Dynamically changing the contents of embedded databrowser Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: install epics-base: Perl Script Path Interpretation Issue on Windows Hussein Matar via Tech-talk
Next: Re: install epics-base: Perl Script Path Interpretation Issue on Windows Ralph Lange via Tech-talk
