1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: install epics-base: Perl Script Path Interpretation Issue on Windows
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 26 Jun 2024 15:31:44 +0000
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA512
That's a problem of make, actually.
The topic is covered in the official Windows installation instructions.
https://urldefense.us/v3/__https://docs.epics-controls.org/en/latest/getting-started/installation-windows.html*windows-path-names__;Iw!!G_uCfscf7eWS!ZdlafAS4_3yKWJ4Ws-SaiP45v3NoDLtAdV1SXZiiPvQ9JRRHUliUpnBOdBmXK7MLUilZ4viwjpIbgIMaZX7W7W-W3IQ$
Cheers,
~Ralph
On 2024-06-26 at 15:25, [email protected] wrote:
> Hi Hussein,
> Unfortunately the EPICS build rules and our Makefiles don't work when the
path to Base or other modules contain spaces, and it would be quite a lot
of work to fix that (patches welcome if it's important to you!). You can't
just change a configuration setting to get around that.
> Thank-you for posting the complete error messages. It looks like you have
Base installed inside a MS Visual Studio BuildTools subdirectory. That is
not a good location, I recommend that you build it somewhere like
C:\epics\base. In addition to Base you will be installing and building
other support modules such as Asyn, so that layout lets you
useC:\epics\asyn for that, and so on.
> Hope this helps,
> - Andrew
> On 6/26/24, 9:26 AM, "Tech-talk" <[email protected]> wrote:
> Hello,
> I am setting up EPICS Base on my Windows 10 machine, but I get a compile
> error when I run the Makefile in the EPICS Base directory:
> perl -CSD C:/Program Files (x86)/Microsoft Visual
> Studio/2022/BuildTools/epics-base/bin/windows-x64/makeMakefile.pl
> O.windows-x64 ../../../..
> Can't open perl script "C:/Program": No such file or directory
> It seems that my compiler does not interpret the path to the Perl script
> correctly, as it only captures the path up to the first space. As a
> result, the Perl script cannot be found.
> Can you tell me why this is happening and how I can fix the problem?
> Which configuration file do I need to edit to correct this?
> The complete output of the makefile:
> make
> C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C
> ./configure install
> make[1]: Entering directory 'C:/Program Files (x86)/Microsoft Visual
> Studio/2022/BuildTools/epics-base/configure'
> O.windows-x64 -f ../Makefile TOP=../.. \
>      T_A=windows-x64 install
> make[2]: Entering directory 'C:/Program Files (x86)/Microsoft Visual
> Studio/2022/BuildTools/epics-base/configure/O.windows-x64'
> make[2]: Nothing to be done for 'install'.
> make[2]: Leaving directory 'C:/Program Files (x86)/Microsoft Visual
> make[1]: Leaving directory 'C:/Program Files (x86)/Microsoft Visual
> C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./src
> install
> Studio/2022/BuildTools/epics-base/src'
> C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./tools
> install
> Studio/2022/BuildTools/epics-base/src/tools'
> O.windows-x64 -f ../Makefile TOP=../../.. \
> make[3]: Entering directory 'C:/Program Files (x86)/Microsoft Visual
> Studio/2022/BuildTools/epics-base/src/tools/O.windows-x64'
> make[3]: Nothing to be done for 'install'.
> make[3]: Leaving directory 'C:/Program Files (x86)/Microsoft Visual
> template/base install
> Studio/2022/BuildTools/epics-base/src/template/base'
> make[2]: *** [../../../configure/RULES_ARCHS:67: O.windows-x64] Error 2
> make[1]: *** [../configure/RULES_DIRS:85: template/base.install] Error 2
> make: *** [configure/RULES_DIRS:85: src.install] Error 2
> Thanks
> Hussein
-----BEGIN PGP SIGNATURE-----
Version: FlowCrypt Email Encryption 8.5.7
Comment: Seamlessly send and receive encrypted email
wnUEARYKACcFgmZ8NF8JkBf1I3sS/czbFiEEZXnpIZOwkN8evX8MF/UjexL9
zNsAAELNAP0f7VU04an++F/wbW1nLwudTafc2Ahl+0WDPGXagt/qNAEA/rJs
jNSnORSrZD1brwNHuJWTpUHp9a0O4LIJCZvD1g8=
=b1no
-----END PGP SIGNATURE-----
Re: install epics-base: Perl Script Path Interpretation Issue on Windows J. Lewis Muir via Tech-talk
install epics-base: Perl Script Path Interpretation Issue on Windows Hussein Matar via Tech-talk
Re: install epics-base: Perl Script Path Interpretation Issue on Windows Johnson, Andrew N. via Tech-talk
Prev: Re: CSS-Phoebus: Dynamically changing the contents of embedded databrowser Kasemir, Kay via Tech-talk
Next: RE: mbbo fields don't match db definitions ??? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: install epics-base: Perl Script Path Interpretation Issue on Windows Johnson, Andrew N. via Tech-talk
Next: Re: install epics-base: Perl Script Path Interpretation Issue on Windows J. Lewis Muir via Tech-talk
