1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: MVME5500 with vxworks6.9
To: whitetiger1123 <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 3 Sep 2024 15:31:45 +0000
> Does the mvme5500 model only support version 5.5 of vxworks?
We are using vxworks 6.9 on 5500 board without any issue.
> If 6.9 version is available, should I flash the bootrom again?
Yes, you should flash it with 6.9 version.
From: Tech-talk <[email protected]> on behalf of whitetiger1123 via Tech-talk <[email protected]>
Date: Monday, September 2, 2024 at 3:11
 AM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] MVME5500 with vxworks6.9
Hello, all.
I'm also struggling with searching the internet and checking the manual, so I'm leaving a question on tech talk.
MVME5500 model completed vxworks system boot. Jumper chose J8 flash0 and vxworks system booted.
But I have a question here. It becomes a vxworks system boot and there are commands for cpu, version, and bsp. Please see below.
VxWorks System Boot
Copyright 1984-2002 Wind River Systems, Inc.
CPU: Motorola MVME5500-0163 - MPC 7455
Version: VxWorks5.5
BSP version: 1.2/1
Creation date: Apr 27 2004, 17:31:50
In this command, does the version guide the vxworks version supported by the mvme5500, or does it show the vxworks version that I previously booted?
I set the st.cmd of vxworks 6.9 the same as the mvme6100 model.
[VxWorks Boot]: p
boot device : geisc
unit number : 0
processor number : 0
host name : host
file name : /usr/local/epics_motor/vxWorks
inet on ethernet (e) : 10.4.134.17:fffff000
inet on backplane (b): 0
host inet (h) : 10.4.133.179
gateway inet (g) : 10.4.128.1
user (u) : daqadmin
ftp password (pw) : pal#2016
flags (f) : 0x0
target name (tn) : test
startup script (s) : host:/usr/local/epics_motor/synApps_5_8/support/motor-6-9/iocBoot/SX_EH_motor/st.cmd
And I tried to run it, but it didn't boot and I kept getting the message [Vxworks Boot]:.
[VxWorks Boot]: @
[VxWorks Boot]:
Does the mvme5500 model only support version 5.5 of vxworks? If 6.9 version is available, should I flash the bootrom again?
I really appreciate of your help.
Best Regards,
Baeg
MVME5500 with vxworks6.9 whitetiger1123 via Tech-talk
Prev: Re: Sequencer RULES_SNCSEQ: No such file or directory Florian Feldbauer via Tech-talk
Next: areaDetector Overlay problem Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: MVME5500 with vxworks6.9 whitetiger1123 via Tech-talk
Next: Build PCAS within the EPICS base LONG FENG via Tech-talk
