1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: areaDetector Overlay problem
From: Jörn Dreyer via Tech-talk <[email protected]>
To: EPICS Talk <[email protected]>
Date: Thu, 05 Sep 2024 09:22:40 +0200
currently I have a problem to get the overlay plugin working. I would like to draw a cursor onto my image.
I have an ADBase set up with an asynPort "cam1". I connect an Overlay plugin "OVER1" to the output of this asynPort with asyn address set to 0.
I defined the cursor "CURSOR1" at NDOverlay8 line 5 and enabled it.
An NDStdArray is connected to asynPort "OVER1".
And here the problem starts. If I set the asyn address to 0, I see the original image from the camera.
If I set it to 1...X nothing happens. No more images are seen.
Shouldn't the overlay plugin add another image to the output att a defined address (5 in this case)?
Or did I understand the functionality of plugins completely wrong?
Any help appreciated.
Joern
Re: areaDetector Overlay problem Mark Rivers via Tech-talk
Prev: Re: MVME5500 with vxworks6.9 Hao, Hao via Tech-talk
Next: Asyn or Stream device interface for struct data Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Sequencer RULES_SNCSEQ: No such file or directory Florian Feldbauer via Tech-talk
Next: Re: areaDetector Overlay problem Mark Rivers via Tech-talk
