Hi Jörn,
No, the plugin does not use different addresses for the output for each overlay (1-8). It always uses address 0.
Each overlay (1-8) is independent and the output image contains all of those overlays that are enabled, so you could have both a cursor and text, for example.
Since you are not seeing the overlay when you use address 0, that could be because of the following:
The NDPluginOverlay itself is not enabled. You must enable both the overlay plugin and the specific overlays (1-8) that you want.
The color of the overlay is not set to a very visible color.
The width is set too small. If the width is 1 and you are using a viewer that downsizes the original image for your screen that can result in some pixels not being displayed at all. Try increasing the width to 3, for example.
Please send a screenshot of NDOverlayN or NDOverlay8 so we can see how you have defined the overlay features.
currently I have a problem to get the overlay plugin working. I would like to draw a cursor onto my image.
I have an ADBase set up with an asynPort "cam1". I connect an Overlay plugin "OVER1" to the output of this asynPort with asyn address set to 0.
I defined the cursor "CURSOR1" at NDOverlay8 line 5 and enabled it.
An NDStdArray is connected to asynPort "OVER1".
And here the problem starts. If I set the asyn address to 0, I see the original image from the camera.
If I set it to 1...X nothing happens. No more images are seen.
Shouldn't the overlay plugin add another image to the output att a defined address (5 in this case)?
Or did I understand the functionality of plugins completely wrong?
Any help appreciated.
Joern
- areaDetector Overlay problem Jörn Dreyer via Tech-talk
Re: Asyn or Stream device interface for struct data Zimoch Dirk via Tech-talk
Adding additional fields to be archived in "policies.py" Windsor Tanner via Tech-talk
<2024>
2025
2026
Asyn or Stream device interface for struct data Abdalla Ahmad via Tech-talk
<2024>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
