1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: Writing XML directly to area detector's NDAttributesFile PV
From: "Pearson, Matthew via Tech-talk" <[email protected]>
To: Érico Nogueira Rolim <[email protected]>, "Wolfman, Mark Frederick" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 24 Sep 2024 15:46:04 +0000
I would also suggest adding the ROI stats data via the statistics plugin and not the HDF plugin. Then the 'type' attribute would be PARAM and not EPICS_PV. If the data is added via the HDF plugin it would be possible to get the previous value and not the latest value, or it's possible the statistics plugin could have already processed a new NDArray and the ROI data then reflects that new data and not the one the HDF plugin is currently saving.
Cheers,
Matt
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Érico Nogueira Rolim via Tech-talk
Sent: Tuesday, September 24, 2024 11:33 AM
To: Wolfman, Mark Frederick <[email protected]>; [email protected]
Subject: [EXTERNAL] Re: Writing XML directly to area detector's NDAttributesFile PV
Hi Mark!
ADCore version is exactly your issue. This feature was added in ADCore R3-13, in commit 02eb9e04d879ae7a1bf609394c1e408f14191bbd.
Cheers,
Érico
On 24/09/2024 12:24, Wolfman, Mark via Tech-talk wrote:
> Hi, all.
> I'm configuring our area detectors to save ROI stats, etc into the HDF files alongside the image data. I'm looking for a way to dynamically set the NDAttributes that get included by the HDF file plugin.
> As a test, I'm using the XML snippet pasted below on our ADSimDet detector (ADCore version 3.12.1). If I put the XML into a file, and put the file path into the PV 25idSimDet:HDF1:NDAttributesFile, then I see the correct attribute in the HDF file.
> The documentation [1] makes it sound like I can put the XML directly into the PV and it should also work as long as "<Attributes>" is in the string, but I do not see the attribute in the HDF5 file, and I get an IOC console error "asynNDArrayDriver::readNDAttributesFile error opening file " followed by the XML I put in.
> I've also tried putting the XML into the camera's NDAttributesFile PV with similar results, and both with and without the "<?xml ?>" declaration. Any ideas on what I'm doing wrong?
> The use case here is that I want Bluesky to include some signals in the AD's HDF file, and also include the right resources in its saved scan entry to find the values later through our data API. Ophyd-async includes support to do this [2] but since my IOC does not let me put the XML into the NDAttributesFile PV, this doesn't work.
> Here is the XML:
>> <?xml version="1.0" encoding="UTF-8"?> <Attributes><Attribute
>> name="sim_det_async-sum" type="EPICS_PV"
>> source="25idSimDet:Stats1:Total_RBV" datatype="DOUBLE"
>> description="Sum of the array" /></Attributes>
> Thanks,
> Mark
> [1]
> https://urldefense.us/v3/__https://areadetector.github.io/areaDetector
> /ADCore/NDArray.html*asynndarraydriver__;Iw!!G_uCfscf7eWS!dh0BK5QPgcb-
> IqTxPFl9IiRRsnBYXRh9MQuybGRWbJh-lrGyjMmjBFSPWaY-MwisKfNGRzLMGIbdenqWWN
> X2xw$ [2]
> https://urldefense.us/v3/__https://github.com/bluesky/ophyd-async/blob
> /main/src/ophyd_async/plan_stubs/_nd_attributes.py__;!!G_uCfscf7eWS!dh
> 0BK5QPgcb-IqTxPFl9IiRRsnBYXRh9MQuybGRWbJh-lrGyjMmjBFSPWaY-MwisKfNGRzLM
> GIbdenqlXczNSA$
> My work schedule may not be the same as your work schedule. Please
> don't feel obligated to respond to this e-mail outside of your normal
> work hours.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
RE: Writing XML directly to area detector's NDAttributesFile PV Mark Rivers via Tech-talk
Writing XML directly to area detector's NDAttributesFile PV Wolfman, Mark via Tech-talk
Re: Writing XML directly to area detector's NDAttributesFile PV Érico Nogueira Rolim via Tech-talk
Prev: Re: Writing XML directly to area detector's NDAttributesFile PV Érico Nogueira Rolim via Tech-talk
Next: Re: Writing XML directly to area detector's NDAttributesFile PV Wolfman, Mark via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: RE: Writing XML directly to area detector's NDAttributesFile PV Mark Rivers via Tech-talk
