Hi, Enrico.
Haha, well I guess that explains it then. I'll look into upgrading the IOC.
Thanks for the reply!
Cheers,
My work schedule may not be the same as your work schedule. Please
don't feel obligated to respond to this e-mail outside of your
normal work hours.
From: Érico Nogueira Rolim <erico.rolim at lnls.br>
Sent: Tuesday, September 24, 2024 10:33
To: Wolfman, Mark; tech-talk at aps.anl.gov
Subject: Re: Writing XML directly to area detector's NDAttributesFile PV
Hi Mark! ADCore version is exactly your issue. This feature was added in ADCore R3-13, in commit 02eb9e04d879ae7a1bf609394c1e408f14191bbd. Cheers, Érico On 24/09/2024 12: 24, Wolfman, Mark via Tech-talk wrote: > Hi, all. > > I'm configuring
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hi Mark!
Cheers,
Érico
On 24/09/2024 12:24, Wolfman, Mark via Tech-talk wrote:
> Hi, all.
> I'm configuring our area detectors to save ROI stats, etc into the HDF files alongside the image data. I'm looking for a way to dynamically set the NDAttributes that get included by the HDF file plugin.
> As a test, I'm using the XML snippet pasted below on our ADSimDet detector (ADCore version 3.12.1). If I put the XML into a file, and put the file path into the PV 25idSimDet:HDF1:NDAttributesFile, then I see the correct attribute in the HDF file.
> The documentation [1] makes it sound like I can put the XML directly into the PV and it should also work as long as "<Attributes>" is in the string, but I do not see the attribute in the HDF5 file, and I get an IOC console error "asynNDArrayDriver::readNDAttributesFile error opening file " followed by the XML I put in.
> I've also tried putting the XML into the camera's NDAttributesFile PV with similar results, and both with and without the "<?xml ?>" declaration. Any ideas on what I'm doing wrong?
> The use case here is that I want Bluesky to include some signals in the AD's HDF file, and also include the right resources in its saved scan entry to find the values later through our data API. Ophyd-async includes support to do this [2] but since my IOC does not let me put the XML into the NDAttributesFile PV, this doesn't work.
> Here is the XML:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <Attributes><Attribute name="sim_det_async-sum" type="EPICS_PV" source="25idSimDet:Stats1:Total_RBV" datatype="DOUBLE" description="Sum of the array" /></Attributes>
> Thanks,
> Mark
> [1] https://urldefense.us/v3/__https://areadetector.github.io/areaDetector/ADCore/NDArray.html*asynndarraydriver__;Iw!!G_uCfscf7eWS!dh0BK5QPgcb-IqTxPFl9IiRRsnBYXRh9MQuybGRWbJh-lrGyjMmjBFSPWaY-MwisKfNGRzLMGIbdenqWWNX2xw$
>[2] https://urldefense.us/v3/__https://github.com/bluesky/ophyd-async/blob/main/src/ophyd_async/plan_stubs/_nd_attributes.py__;!!G_uCfscf7eWS!dh0BK5QPgcb-IqTxPFl9IiRRsnBYXRh9MQuybGRWbJh-lrGyjMmjBFSPWaY-MwisKfNGRzLMGIbdenqlXczNSA$
> normal work hours.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- Writing XML directly to area detector's NDAttributesFile PV Wolfman, Mark via Tech-talk
- Re: Writing XML directly to area detector's NDAttributesFile PV Érico Nogueira Rolim via Tech-talk
RE: Writing XML directly to area detector's NDAttributesFile PV Pearson, Matthew via Tech-talk
Re: archive appliance some PVs no data Michael Davidsaver via Tech-talk
<2024>
2025
Re: Writing XML directly to area detector's NDAttributesFile PV Wolfman, Mark via Tech-talk
Using alternative build systems (meson) for IOCs/modules Érico Nogueira Rolim via Tech-talk
<2024>
2025
