1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Dynamically change file in embedded screen
From: Alessandra Palazzo via Tech-talk <[email protected]>
Date: Thu, 10 Oct 2024 09:48:25 +0000
Hi all,
is it  possible in Phoebus to dynamically change the file loaded in an embedded display?
I tried to create a display with an action button and an embedded display; the "file" field of the embedded display is a pv whose value is overwritten by clicking on the button.
This however doesn’t seem to work.
Best regards,
Alessandra Palazzo
Control System Engineer
Present: Mon - Tue - Wed - Thu - Fri
High Voltage Engineering Europa B.V.
Amsterdamseweg 63, 3812 RR Amersfoort
P.O. Box 99, 3800 AB Amersfoort, The Netherlands
Tel       +31334619741
Fax      +31334615291
E-mail  [email protected]
Web     www.highvolteng.com
RE: Dynamically change file in embedded screen CHOQUET Antoine via Tech-talk
Prev: Re: Video Matrix Switcher Mrinal Bera via Tech-talk
Next: Re: OPCUA SSL problem Zimoch Dirk via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: RE: Dynamically change file in embedded screen CHOQUET Antoine via Tech-talk
