1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: Dynamically change file in embedded screen
From: CHOQUET Antoine via Tech-talk <[email protected]>
To: Alessandra Palazzo <[email protected]>
Date: Fri, 11 Oct 2024 10:09:08 +0000
Hello,
Here is an embedded python script that I use on an embedded display to update the file path:
from org.csstudio.display.builder.runtime.script import PVUtil
channel = PVUtil.getString(pvs[0])
#Reload window
widget.setPropertyValue("file", "")
widget.setPropertyValue("file", channel)
Then I use action buttons to write the path of the file to be opened in the embedded display. The action button writes the path as a string to a local pv, which the script above retrieves with pvs[0] (the script is triggered when the PV value changes).
Best Regards,
Antoine Choquet.
CEA - DRF/Irfu/DIS/LDISC
De : Tech-talk <[email protected]> de la part de Alessandra Palazzo via Tech-talk <[email protected]>
Envoyé : jeudi 10 octobre 2024 11:48:25
À : [email protected]
Objet : Dynamically change file in embedded screen
Hi all,
is it  possible in Phoebus to dynamically change the file loaded in an embedded display?
I tried to create a display with an action button and an embedded display; the "file" field of the embedded display is a pv whose value is overwritten by clicking on the button.
This however doesn’t seem to work.
Best regards,
Alessandra Palazzo
Control System Engineer
Present: Mon - Tue - Wed - Thu - Fri
High Voltage Engineering Europa B.V.
Amsterdamseweg 63, 3812 RR Amersfoort
P.O. Box 99, 3800 AB Amersfoort, The Netherlands
Tel       +31334619741
Fax      +31334615291
E-mail  [email protected]
Web     www.highvolteng.com
Dynamically change file in embedded screen Alessandra Palazzo via Tech-talk
Prev: Re: OPCUA SSL problem Michael Davidsaver via Tech-talk
Next: How to display subgroup in embedded screen Alessandra Palazzo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Dynamically change file in embedded screen Alessandra Palazzo via Tech-talk
