Hi folks, Thanks again for your help! Mark C: I was able to build and test 4-0-02 and can verify that setting the value of the CS motor seems to work well. Thanks for adding that feature! The only odd thing I'm seeing is that when I move in the backlash direction of the motors there's a settling period at the end of the motion that almost looks like the motor servoing to find the right position (this is a stepper motor). I assume it's something to do with how the CS axis is handling the backlash. It gets there eventually, but definitely adds a second or two to each position change. Mark R: That did the trick! I appreciate the recommendation to take a look at the xxx module. We're working on updating much of our EPICS controls here, but have lost a lot of our local expertise since we last did this, so I'm kind of fumbling along and learning as I go. I will say that for a (relative) novice like myself, the softmotor thing was particularly tricky because it's not mentioned in any of the motor module documentation and it's not listed as a separate motor module (like, say, motorNewport) so I wasn't aware that it needed the separate import. Easy to see it once I look in the xxxApp Makefile, so that's definitely helpful. I'll play with the two approaches and see which works best for our applications. All the best. - Jesse Jesse Hopkins, PhD Deputy Director BioCAT, Sector 18 Advanced Photon Source On Thu, Oct 17, 2024 at 2:39 AM Mark Clift via Tech-talk <[email protected]> wrote:
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
