1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Phoebus: how to lock split panels size
From: Alessandra Palazzo via Tech-talk <[email protected]>
Date: Thu, 17 Oct 2024 13:50:44 +0000
Hi all,
is it possible in Phoebus to save a layout with split panel whose size is locked and cannot be changed?
Best regards,
Alessandra Palazzo
Control System Engineer
Present: Mon - Tue - Wed - Thu - Fri
High Voltage Engineering Europa B.V.
Amsterdamseweg 63, 3812 RR Amersfoort
P.O. Box 99, 3800 AB Amersfoort, The Netherlands
Tel       +31334619741
Fax      +31334615291
E-mail  [email protected]
Web     www.highvolteng.com
Prev: Re: [Ext] RE: Help setting up coordinated motions for Galil controller Mark Clift via Tech-talk
Next: Re: [Ext] RE: Help setting up coordinated motions for Galil controller Jesse Hopkins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: [Ext] RE: Help setting up coordinated motions for Galil controller Jesse Hopkins via Tech-talk
Next: Use EPICS 7.0.* in production? J. Lewis Muir via Tech-talk
