1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Use EPICS 7.0.* in production?
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 17 Oct 2024 21:37:59 -0500
Hello, Tech-Talkers!
Is EPICS 7.0.8 a developer release that should not be used in
production?
I ask because at
  https://urldefense.us/v3/__https://epics.anl.gov/base/index.php__;!!G_uCfscf7eWS!ZTt7qznz4xlCwL0cLoMwgMnloSX9BTr-0EiUhx6uKrAeLVJE-vulKmvU6Lz7yyvTTtamLbmUGhW-AjdXhDOBZg$
it says in the "Versions and Numbering" section:
  The EPICS Version numbering system has evolved over the years so older
  version numbers may not mean quite the same thing as more recent ones,
  but any version with a zero component in the number such as 3.15.0.1
  was a developer release and should not be used for production systems.
  The first release in the 3.15 series that qualified for production use
  was version 3.15.1.
Since EPICS 7.0.8 has a zero component, does that mean it is a developer
release that should not be used in production?  Or is the wording of
the above not quite right, and what it really means is that there can
be a zero component in the series name (e.g., "7.0"), and only if
there's a zero component outside of the series name in the version
(e.g., "7.0.0.1") is it a developer release?
Thanks!
Lewis
Re: Use EPICS 7.0.* in production? Johnson, Andrew N. via Tech-talk
Prev: Re: [Ext] RE: Help setting up coordinated motions for Galil controller Mark Clift via Tech-talk
Next: Help understanding DTYP Soft Timestamp Marco Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Phoebus: how to lock split panels size Alessandra Palazzo via Tech-talk
Next: Re: Use EPICS 7.0.* in production? Johnson, Andrew N. via Tech-talk
