1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Help understanding DTYP Soft Timestamp
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Marco Filho <[email protected]>, Ralph Lange <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 21 Oct 2024 15:33:28 +0000
The record conversion uses your OS's strftime() routine for everything except the "%f" format conversion. You may need to use %09f for that fractional part though to get the right output — I haven’t checked but I suspect %f will convert a fraction of 1 nanosecond as the string "1" whereas after the decimal point you would need "000000001".
- Andrew
On 10/21/24, 11:11 AM, "Tech-talk" <[email protected]> wrote:
Thanks all for the answers.
I expected something about the formatting, In the example record:
field(INP,  "@%s.%f")
seems to do the work fine but I tried playing with it and didn't get very far. Even though it seems similar to c format strings It doesn't seem to have the same meaning.
Anyway, it works the way it's intended to.
Cheers,
Marco
From: Tech-talk <[email protected]> on behalf of Ralph Lange via Tech-talk <[email protected]>
Sent: 19 October 2024 17:10:19
To: EPICS Tech Talk
On Fri, 18 Oct 2024 at 21:08, J. Lewis Muir via Tech-talk <[email protected]> wrote:
I would expect to find information about the DTYP="Soft Timestamp" device
support here, or if not here, at least a link to information about it here.
I think it would be good for the reference manual
to be consistent in where it documents fields for each record.
Happy to review your pull requests.
~Ralph
Help understanding DTYP Soft Timestamp Marco Filho via Tech-talk
Re: Help understanding DTYP Soft Timestamp Johnson, Andrew N. via Tech-talk
Re: Help understanding DTYP Soft Timestamp J. Lewis Muir via Tech-talk
Re: Help understanding DTYP Soft Timestamp Ralph Lange via Tech-talk
Re: Help understanding DTYP Soft Timestamp Marco Filho via Tech-talk
Prev: Re: Help understanding DTYP Soft Timestamp Marco Filho via Tech-talk
Next: Job Opening BESSY-II EPICS and Bluesky Smith, William via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: adding ffmpegServer plugin to IOC John Dobbins via Tech-talk
