1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: streamDevice configuration issues with serial ports
To: [email protected]
Date: Tue, 29 Oct 2024 09:26:30 +0800
Hi all,
     I have a sensor that communicates via RS485 with the Modbus RTU protocol. I want to use streamDevice to read the sensor values, but I've found that there is no data transmission between the system and the sensor, and the following issues have occurred:
epics> 2024/10/28 21:00:05.370941 SI Sensor:Data: No reply within 10000 ms to "<01><04><00><00><00><06>p<08><0d><0a>"
2024/10/28 21:00:20.484243 SI Sensor:Data: No reply within 10000 ms to "<01><04><00><00><00><06>p<08><0d><0a>"
2024/10/28 21:00:35.322913 SI Sensor:Data: No reply within 10000 ms to "<01><04><00><00><00><06>p<08><0d><0a>"
2024/10/28 21:00:50.427348 SI Sensor:Data: No reply within 10000 ms to "<01><04><00><00><00><06>p<08><0d><0a>"
    My protocol(RS485Test.proto) file is written like this:
Terminator = CR LF;
InTerminator = CR LF;
ReplyTimeout = 10000;
ReadTimeout = 10000;
getData
  out "\x01\x04\x00\x00\x00\x06\x70\x08";
  in "%r";
    Record(RS485Test.db):
record(ai, "Sensor:Data")
    field(DTYP, "stream")
    field(INP, "@RS485Test.proto getData SI")
    field(SCAN, "5 second")
    IOC st.cmd:
#!../../bin/linux-x86_64/dataProcessing
< envPaths
dbLoadDatabase("../../dbd/dataProcessing.dbd",0,0)
dataProcessing_registerRecordDeviceDriver pdbbase
epicsEnvSet ("STREAM_PROTOCOL_PATH", "/home/training/examples/dataProcessingApp/Db")
drvAsynSerialPortConfigure("SI", "/dev/ttyS3")
asynSetOption("SI", 0, "baud", "9600")
asynSetOption("SI", 0, "bits", "8")
asynSetOption("SI", 0, "parity", "none")
asynSetOption("SI", 0, "stop", "1")
asynSetOption("SI", 0, "clocal", "Y")
asynSetOption("SI", 0, "crtscts", "N")
## Load record instances
dbLoadRecords("../../db/RS485Test.db")
iocInit()
    Is there anything wrong with these?
Re: streamDevice configuration issues with serial ports Michael Davidsaver via Tech-talk
RE: streamDevice configuration issues with serial ports Mark Rivers via Tech-talk
Prev: RE: asyn port locking while motorIMS controller limit-switch configuration is read Mark Rivers via Tech-talk
Next: Re: streamDevice configuration issues with serial ports Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: RE: Review of submission for new QuadEM Mark Rivers via Tech-talk
