1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: [External] Cs studio cannot load model form
From: "Leblanc, Gregory via Tech-talk" <[email protected]>
To: "Saunders, Wyatt" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 31 Oct 2024 16:01:12 +0000
Wyatt,
I was able to fix this error by running ‘sudo dnf update’ and then ‘sudo dnf install java-11-openjdk’ .  I think somehow the headless version of java got installed and one of the rolling updates to java was broken on centos 9 stream.
     Greg
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701 USA
[email protected]
M: (401) 52-OUAL1 or (401) 526-8251
https://orcid.org/0000-0001-7899-5296
From: Tech-talk <[email protected]> On Behalf Of Saunders, Wyatt via Tech-talk
Sent: Wednesday, October 30, 2024 11:27 AM
To: [email protected]
Subject: [External] Cs studio cannot load model form
Use caution with links and attachments.
subject : I am having issues with CS studio after switching release versions.
Hi, this morning I wanted to run cs studio I was originally using the latest snapshot. however, my Java Runtime was not up to date and could not recognize class file version 61.0 and could only recognize up to 55.0. I decided to switch to an official release of cs-studio so i would not have to worry about updating things.
this is the current configuration I have
installed location:      /home/saunders/cs_studio/Phoebus-4.7.3-linux/product-4.7.3
current user directory:   /home/saunders/cs_studio/Phoebus-4.7.3-linux/product-4.7.3
java home:            /usr/lib/jvm/java-11-openjdk-11.0.20.1.1-2.el9.x86_64
cs studio version:       4.7.3
java version            Oracle Corporation 11.0.20.1+1-LTS
java FX vesion          19+11
cs studio will now open but when i try to run one of the .bob files to test one of my displays i get the following error pop up with the following text
cannot load model from
/home/saunders/cs_studio/vacumeguagetest.bob
could not initialize class java.awt.Color
java.lang.NoClassDefFoundError: could not initialize class java.awt.Color
Cause:
[1] could not initialize class java.awt.Color
under the see details it says this
java.util.concurrent.ExecutionException: java.lang.NoClassDefFoundError: Could not initialize class java.awt.Color
      at java.base/java.util.concurrent.FutureTask.report(FutureTask.java:122)
      at java.base/java.util.concurrent.FutureTask.get(FutureTask.java:191)
      at org.csstudio.display.builder.runtime.app.DisplayRuntimeInstance.lambda$loadDisplayFile$4(DisplayRuntimeInstance.java:304)
      at org.phoebus.framework.jobs.Job.execute(Job.java:50)
      at org.phoebus.framework.jobs.JobManager.execute(JobManager.java:54)
      at org.phoebus.framework.jobs.JobManager.lambda$schedule$0(JobManager.java:45)
      at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
      at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
      at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
      at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class java.awt.Color
      at org.csstudio.display.builder.representation.javafx.JFXRepresentation.updateBackground(JFXRepresentation.java:855)
      at org.csstudio.display.builder.representation.javafx.JFXRepresentation.execute(JFXRepresentation.java:672)
      at org.csstudio.display.builder.representation.javafx.JFXRepresentation.lambda$new$1(JFXRepresentation.java:153)
      at org.csstudio.display.builder.representation.javafx.JFXRepresentation.representModel(JFXRepresentation.java:642)
      at org.csstudio.display.builder.runtime.app.DockItemRepresentation.representModel(DockItemRepresentation.java:142)
      at org.csstudio.display.builder.runtime.app.DisplayRuntimeInstance.representModel(DisplayRuntimeInstance.java:400)
      at org.csstudio.display.builder.runtime.app.DisplayRuntimeInstance.lambda$loadDisplayFile$2(DisplayRuntimeInstance.java:303)
      at com.sun.javafx.application.PlatformImpl.lambda$runLater$10(PlatformImpl.java:457)
      at java.base/java.security.AccessController.doPrivileged(Native Method)
      at com.sun.javafx.application.PlatformImpl.lambda$runLater$11(PlatformImpl.java:456)
      at com.sun.glass.ui.InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:96)
      at com.sun.glass.ui.gtk.GtkApplication._runLoop(Native Method)
      at com.sun.glass.ui.gtk.GtkApplication.lambda$runLoop$11(GtkApplication.java:316)
      ... 1 more
this is the case for any of the displays I try and run including the displays that come with the program including the home display. If anyone has any insight into what is going on here please let me know
thanks,
Wyatt
Cs studio cannot load model form Saunders, Wyatt via Tech-talk
Prev: Re: genSubRecord.h not found Andy Foster via Tech-talk
Next: Re: pasynOctetSyncIO->read() weirdly slow performance Marco Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Cs studio cannot load model form Saunders, Wyatt via Tech-talk
Next: genSubRecord.h not found LONG FENG via Tech-talk
