1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Procserv execute error
To: Mark Rivers <[email protected]>, 백호령 <[email protected]>
Date: Fri, 1 Nov 2024 17:45:46 +0000
Manualy typing “procServ …” to start an IOC is not a good practice unless it is just for a quick test.
Suppose you are going to run a dozen (or a few hundreds) of  softIOCs on a Linux server, you probably should use a more advanced tool (built upon procServ) for running and managing those IOCs. Here is one of those tools: https://github.com/NSLS-II/systemd-softioc. You are welcome to try it out and let me know if you need any help.
Cheers,
Yong
NSLS-2 Accelerator Controls
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Date: Friday, November 1, 2024 at 8:26 AM
To:
Cc: [email protected] <[email protected]>
I suggest putting the complete path to CXIKSS_st.cmd in the procServ command.
Sent from my iPhone
> On Nov 1, 2024, at 2:00
 AM, 백호령 via Tech-talk <[email protected]> wrote:
> Hi, i'd like to take your advice about procserv error.
> I was use very well procserv before, but I don't know why I couldn't use it now.
> I did install again epics and synapps. Is this the reason why I couldn't use procserv?
> the error message is :
> (3_8) [root@psc02 CXIKSS]# procServ -L CXIKSS.log 20000 CXIKSS_st.cmd
> procServ: spawning daemon process: 4165
> (3_8) [root@psc02 CXIKSS]# telnet localhost 20000
> Trying ::1...
> telnet: connect to address ::1: Connection refused
> Trying 127.0.0.1...
> Connected to localhost.
> Escape character is '^]'.
> @@@ Welcome to procServ (procServ Process Server 2.8.0)
> @@@ Use ^X to kill the child, auto restart mode is ON, use ^T to toggle auto restart
> @@@ procServ server PID: 4165
> @@@ Server startup directory: /usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/iocBoot/iocOmsAsyn/CXIKSS
> @@@ Child startup directory: /usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/iocBoot/iocOmsAsyn/CXIKSS
> @@@ Child started as: CXIKSS_st.cmd
> @@@ Child log file: CXIKSS.log
> @@@ Child "CXIKSS_st.cmd" is SHUT DOWN
> @@@ procServ server started at: Fri Nov 1 15:26:44 2024
> @@@ 0 user(s) and 0 logger(s) connected (plus you)
> @@@ ^R or ^X restarts the child, ^Q quits the server
> @@@ Restarting child "CXIKSS_st.cmd"
> @@@ The PID of new child "CXIKSS_st.cmd" is: 4168
> procServ: child could not execute: CXIKSS_st.cmd, No such file or directory
> @@@ Received a sigChild for process 4168. Normal exit status = 255
> @@@ Current time: Fri Nov 1 15:26:59 2024
> @@@ Child process is shutting down, a new one will be restarted shortly
> telnet> quit
> But I have a st.cmd file in my directory, and it worked very well when I use st.cmd file like this > ./CXIKSS_st.cmd
> Can you guys please help me about this?
> Sincerely,
> Baeg
Procserv execute error 백호령 via Tech-talk
Re: Procserv execute error Mark Rivers via Tech-talk
Prev: Re: asyn port locking while motorIMS controller limit-switch configuration is read Mark Rivers via Tech-talk
Next: Re: IOC Shell Persist history: ERROR Permission denied (13) writing '.iocsh_history' Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Procserv execute error Mark Rivers via Tech-talk
Next: Archiver Appliance missing aplliance.properties file Sintschuk, Michael via Tech-talk
