Hello, EPICS mates, I use module Eurotherm2k (https://github.com/jwlodek/eurotherm2k) to access controller Eurothermm 3508. It's ok mostly, but I can't set the P/I/D values. And there are two errors showed repeatedly: 2024/11/07 09:07:35.155 drvModbusAsyn::readPoller port Eurotherm_E3K01_1_1_Rd_PID invalid memory request 3, max=3 2024/11/07 09:07:35.852 drvModbusAsyn::readPoller port Eurotherm_E3K01_1_1_Rd_PV invalid memory request 4, max=3 In "
E3K01_1_1" "E3K01" is the port name, the following "1" is the Modbus address, then "1" is the loop number. I found that in the file eurothermModbus.c of the module, it calls drvMosbusAsynConfigure: /* Create modbus channels for the PV, target setpoint and manual output */ mkname(str, strmaxlen, asynPortName, modbusAddress, loopNumber, 0, "PV"); asynRet = drvModbusAsynConfigure(str, asynPortName, modbusAddress, MODBUS_READW, loopStart+PV_OFFSET, 3+2, 0, EUROTHERM_POLL_MS, ""); if (asynRet != asynSuccess) { LOG_ERROR("drvModbusAsynConfigure failed with error %d", asynRet); free(str); return -EIO; } /* Create modbus channels for the PID parameters */ mkname(str, strmaxlen, asynPortName, modbusAddress, loopNumber, 0, "PID"); asynRet = drvModbusAsynConfigure(str, asynPortName, modbusAddress, MODBUS_READW, loopStart+PID_OFFSET, 3+1, 0, EUROTHERM_POLL_MS, ""); if (asynRet != asynSuccess) { LOG_ERROR("drvModbusAsynConfigure failed with error %d", asynRet); free(str); return -EIO; } And in the file eurothermModbusLoop.template, the records uses the ports created above: # PV: address 1 # % gdatag,pv,ro,$(gda_name=),PVRBV # % archiver 1 Monitor record(ai, "$(P)$(Q):PV:RBV") { field(DESC, "Temperature Readback") field(DTYP, "asynInt32") field(INP, "@asyn(Eurotherm_$(PORT)_$(ADDR)_$(LOOP=1)_Rd_PV,0,1000)MODBUS_DATA") field(EGU, "$(EGUT=C)") field(SCAN, "I/O Intr") } # % gdatag,pv,ro,$(gda_name=),SPRBV # % archiver 10 Monitor record(ai, "$(P)$(Q):SP:RBV") { field(DESC, "Setpoint Readback") field(DTYP, "asynInt32") field(INP, "@asyn(Eurotherm_$(PORT)_$(ADDR)_$(LOOP=1)_Rd_PV,1,1000)MODBUS_DATA") field(EGU, "$(EGUT=C)") field(SCAN, "I/O Intr") field(ASLO, "0.1") } # % gdatag,pv,ro,$(gda_name=),ORBV # % archiver 1 Monitor record(ai, "$(P)$(Q):O:RBV") { field(DESC, "Output Readback") field(DTYP, "asynInt32") field(INP, "@asyn(Eurotherm_$(PORT)_$(ADDR)_$(LOOP=1)_Rd_PV,2,1000)MODBUS_DATA") field(EGU, "%") field(SCAN, "I/O Intr") field(ASLO, "0.1") field(PREC, "1") } Would you please provide some suggestions?
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
