1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Multiple asyn ports inside asynPortDriver class
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Thu, 7 Nov 2024 12:14:05 +0000
Hi
I am writing an EPICS driver for an Ethernet-based device in which the control interface is split between TCP and UDP layers of the same port number (i.e., registers IO is through UDP while waveforms is through TCP). I have to create two asyn ports using drvAsynIPPortConfigure function, so my question is are there any consideration regarding this approach? Because I am noticing some timeout issues, most likely from the device’s side, so I want to narrow the issue as much as I can. Thanks in advance.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
P.O. Box 7, Allan 19252, Jordan
Tel: +96253511348 , ext. 265
Fax: +96253511423
Email : [email protected]
Website: www.sesame.org.jo
Re: Multiple asyn ports inside asynPortDriver class Mark Rivers via Tech-talk
Prev: RE: EPICS Archiver compatibility w/Debian 12, Tomcat 10 Sky Brewer via Tech-talk
Next: Re: Multiple asyn ports inside asynPortDriver class Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: Error "drvModbusAsyn::readPoller ... invalud memory request 3, max=3" of module Eurotherm2k LiangChih Chiang via Tech-talk
