1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: IOClog
From: Miroslaw Dach via Tech-talk <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 7 Nov 2024 12:17:40 -0800
Hi All,
We have experimented with logstash and we have the environment setup for caput log and error messages setup.
All seems to work fine when saving datas into the logfiles.
The configuration for logstash which Andrew has summarised:
https://events01.synchrotron.org.au/event/85/contributions/2601/attachments/689/997/5_06_Logstash_for_IOCs.pdf
was very helpful.
Do you have a similar summary for elastic search and Kibana configuration?
Best Regards
Mirek
Subject: Re: IOClog
From: "Konrad, Martin via Tech-talk" <[email protected]>
To: Neil Hamilton Jr <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 2 May 2019 13:36:10 +0000
Hi Neil,
> Is the recommended logging facility IOClog?
20 years ago it was a good choice. If you are looking for a simple
solution for testing it might still get the job done.
For production use there are more powerful tools around, though. Some
labs including ANL and FRIB are successfully using Logstash now which is
very popular in the IT world (there is a good chance your sysadmin is
already using it for system log files etc.). You might want to consider
pairing Logstash with the Elastic Stack to allow fast search and Kibana
for visualization. Andrews had a few slides about how to configure it to
receive EPICS log messages:
Unfortunately, we didn't find time to document this properly. We
appreciate your help turning Andrews slides into a description that can
go into our official documentation.
Martin
Re: IOClog Dale Cox via Tech-talk
Prev: Re: [EXTERNAL] Re: Asyn device support does not reconnect Miroslaw Dach via Tech-talk
Next: Re: IOClog Dale Cox via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Asyn device support does not reconnect Miroslaw Dach via Tech-talk
