1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: IOClog
To: Miroslaw Dach <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 7 Nov 2024 15:02:19 -0600
At NEXTLab, we use rsyslog to ship the logs out to a remote server.  I was looking for more than just the IOC errors that come across the error log.  We log all of the console output to a log file, then use rsyslog to send that to a central log storage server for review later.
For reviewing/analytics, we use Grafana.  To get the data into a datasource so grafana can show it, we use a pipeline of Promtail > Loki running on the log server.  It works well, and if you set your dashboard up right, you can do searches and analytics pretty easily.
It also pairs with other grafana-focused tools like Prometheus.  We can run the node-exporter on our IOC machines and view the logs alongside hardware stats like CPU / RAM usage, etc.
This workflow has made me want to start logging other stuff to that same location.
It's great that there are so many IT-centric tools out there that have solved a lot of this.
Dale
On Thu, Nov 7, 2024 at 2:18 PM Miroslaw Dach via Tech-talk <[email protected]> wrote:
Hi All,
We have experimented with logstash and we have the environment setup for caput log and error messages setup.
All seems to work fine when saving datas into the logfiles.
The configuration for logstash which Andrew has summarised:
https://events01.synchrotron.org.au/event/85/contributions/2601/attachments/689/997/5_06_Logstash_for_IOCs.pdf
was very helpful.
Do you have a similar summary for elastic search and Kibana configuration?
Best Regards
Mirek
Subject: Re: IOClog
From: "Konrad, Martin via Tech-talk" <[email protected]>
To: Neil Hamilton Jr <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 2 May 2019 13:36:10 +0000
Hi Neil,
> Is the recommended logging facility IOClog?
20 years ago it was a good choice. If you are looking for a simple
solution for testing it might still get the job done.
For production use there are more powerful tools around, though. Some
labs including ANL and FRIB are successfully using Logstash now which is
very popular in the IT world (there is a good chance your sysadmin is
already using it for system log files etc.). You might want to consider
pairing Logstash with the Elastic Stack to allow fast search and Kibana
for visualization. Andrews had a few slides about how to configure it to
receive EPICS log messages:
Unfortunately, we didn't find time to document this properly. We
appreciate your help turning Andrews slides into a description that can
go into our official documentation.
Martin
Dale Cox
Instrumentation and Electrical Engineer
ACU NEXT Lab
Re: IOClog Saisrikiran Mudigonda via Tech-talk
Re: IOClog Miroslaw Dach via Tech-talk
Prev: Re: IOClog Miroslaw Dach via Tech-talk
Next: Re: Error "drvModbusAsyn::readPoller ... invalud memory request 3, max=3" of module Eurotherm2k LiangChih Chiang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Next: Re: IOClog Saisrikiran Mudigonda via Tech-talk
