1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: [EXTERNAL] Phoebus settings.ini - Path to predefined Colors and Fonts
From: "Dr. Simon Friederich via Tech-talk" <[email protected]>
To: "Kasemir, Kay" <[email protected]>, "Dmitry Yu. Bolkhovityanov" <[email protected]>
Date: Mon, 18 Nov 2024 17:30:43 +0100
Hi there,
update:
Works for Linux:
    org.csstudio.display.builder.model/color_files=$(phoebus.install)/mesa_color.def
    org.csstudio.display.builder.model/font_files=$(phoebus.install)/mesa_font.def
Although exanded correctly, does not work for Windows (example for color only):
    org.csstudio.display.builder.model/color_files=file:$(phoebus.install)/mesa_color.def
    org.csstudio.display.builder.model/color_files=file:///$(phoebus.install)/mesa_color.def
The following does work for Windows (as the color and font files are located next everything else in the app directory), the default path seems to be $(phoebus.install) if I saw that correctly:
    org.csstudio.display.builder.model/color_files=app/mesa_color.def
But this line does not work for Linux :-(. I had hoped to get a common solution for Linux and Windows.
Another follow-up question: Is it possible to have multiple settings.ini files? E.g. common settings in the phoebus.install location and some special settings (e.g. org.phoebus.pv.ca/addr_list=..) for special clients.
As I've followed the jpackaging-Tutorial (https://github.com/ControlSystemStudio/phoebus/tree/master/phoebus-product#building-native-installers-with-jpackage) I can't use the command line options anymore (like --help or --settings <path_to_settings.ini>). Maybe I did something wrong.
Best regards
Simon
Am 13.11.2024 um 15:34 schrieb Kasemir, Kay:
You can try “file:…” URL syntax:
    org.csstudio.display.builder.model/color_files=file:///Program%20Files/mesa-phoebus-win/app/mesa_color.def
That should work, but now you rely on /Program Files/mesa-phoebus-win/… as the install location.
If you prefer to use the install location from the system property,
then unfortunately that might expand into this and fail because of the space:
   org.csstudio.display.builder.model/color_files=file:///Program Files/mesa-phoebus-win/app/mesa_color.def
Maybe you can put something clever into your launcher *.bat file:
Locate the install location, turn that into a proper “file://with_%20_for_spaces”, then start phoebus with that install location?
  @java -Dphoebus.install=…
From: Tech-talk <[email protected]> on behalf of Dmitry Yu. Bolkhovityanov via Tech-talk <[email protected]>
Date: Wednesday, November 13, 2024 at 8:22
AM
To: Dr. Simon Friederich <[email protected]>
Cc: [email protected] <[email protected]>
Hi!
Have you tried "8.3 alias" for "Program Files" - "progra~1"?  I.e.
org.csstudio.display.builder.model/color_files=C:/progra~1/mesa-phoebus-win/app/mesa_color.def
org.csstudio.display.builder.model/font_files=C:/progra~1/mesa-phoebus-win/app/mesa_font.def
On Wed, 13 Nov 2024, Dr. Simon Friederich via Tech-talk wrote:
> Hi Kay,
> Now I see. It seems that for Windows the expansion does not work properly due
> to the whitespace in "Program Files" *facepalm*:
> org.csstudio.display.builder.model/color_files=C:/Program%20Files/mesa-phoebus-win/app/mesa_color.def
> org.csstudio.display.builder.model/font_files=C:/Program%20Files/mesa-phoebus-win/app/mesa_font.def
> Seems like I need to find another workaround.
> Best regards
> Am 12.11.2024 um 18:14 schrieb Kasemir, Kay:
>> >  Without success I've tried
>>  Curious. When I try it, system properties like
>>  $(user.home)
>>  $(phoebus.home)
>>  $(phoebus.install)
>>  are all expanded in the color_files or font_files setting.
>>  *From: *Tech-talk <[email protected]> on behalf of Dr. Simon
>>  Friederich via Tech-talk <[email protected]>
>>  *Date: *Tuesday, November 12, 2024 at 4:00?AM
>>  *To: *[email protected] <[email protected]>
>>  *Subject: *[EXTERNAL] Phoebus settings.ini - Path to predefined Colors and
>>  Fonts
>>  Dear all,
>>  I'd like to add custom colors and fonts in Phoebus.
>>  If I specify the full path, e.g. (Windows)
>>  org.csstudio.display.builder.model/color_files=C:\\Program
>>  Files\\mesa-phoebus-win\\app\\mesa_color.def
>>  org.csstudio.display.builder.model/font_files=C:\\Program
>>  Files\\mesa-phoebus-win\\app\\mesa_font.def
>>  or (Linux)
>>   org.csstudio.display.builder.model/color_files=/home/mesa/phoebus-product/mesa_color.def
>>   org.csstudio.display.builder.model/font_files=/home/mesa/phoebus-product/mesa_font.def
>>  This works as expected.
>>  Yet I'd like to use relative paths as I've successfully used jpackage to
>>  build installers for Windows and Linux.
>>  Other spellings,
>>  ...=./mesa_color.def
>>    ...=./mesa_font.def
>>  where $(phoebus.install) should point to the correct path as
>>  "site_welcome.html" is in the same path and works as expected (Also
>>  Help->About->Details->System Properties show phoebus.install).
>>  Do you know how to achieve this?
>>  Best regards
>>  Simon
>>  Institut f?r Kernphysik
>>  Kollaboration B | MESA
>>  Johannes Gutenberg-Universit?t Mainz
>>  Johann-Joachim-Becher-Weg 45
>>  D 55128 Mainz
>>  Tel.: +49 (0)6131 39-23160
>>  E-Mail:[email protected]
Re: [EXTERNAL] Phoebus settings.ini - Path to predefined Colors and Fonts Kasemir, Kay via Tech-talk
Phoebus settings.ini - Path to predefined Colors and Fonts Dr. Simon Friederich via Tech-talk
Re: [EXTERNAL] Phoebus settings.ini - Path to predefined Colors and Fonts Dr. Simon Friederich via Tech-talk
Re: [EXTERNAL] Phoebus settings.ini - Path to predefined Colors and Fonts Dmitry Yu. Bolkhovityanov via Tech-talk
Prev: Using separate .json files for NTTable definitions Érico Nogueira Rolim via Tech-talk
Next: Re: [EXTERNAL] Phoebus settings.ini - Path to predefined Colors and Fonts Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: [EXTERNAL] Phoebus settings.ini - Path to predefined Colors and Fonts Kasemir, Kay via Tech-talk
