1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Using separate .json files for NTTable definitions
From: Érico Nogueira Rolim via Tech-talk <[email protected]>
Date: Mon, 18 Nov 2024 15:02:07 +0000
Hi all!
I'm trying out using group definitions to create NTTable groups with
related information to be served by my IOC. I managed to make them work
with the "info(Q:group, ...)" fields in databases, but, when I tried to
use a separate .json file (not as relevant for my current use case, but
seems like it would be useful when retrofitting tables into existing
modules), I couldn't get it to work.
This is the definition I tried to use:
   "$(P)$(R)EventTable2-Mon": {
     "+id": "epics:nt/NTTable:1.0",
     "labels": {"+type": "plain", "+channel": "$(P)$(R)bufferLABELS"},
     "value.A": {"+type": "plain", "+channel": "$(P)$(R)TSbuffer.VAL"},
     "value.B": {"+type": "plain", "+channel":
"$(P)$(R)EVENTbuffer.VAL", "+trigger": "*"},
Without quotes around the mapping names, I got errors from the json
parser, with both PVXS and epics-base's *CPP implementation:
Error from dbGroup file "../../db/event_log.json"
Error on line 3 : lexical error: invalid char in json text.
                                        +id: "epics:nt/NTTable:1.0",
                      (right here) ------^
However, with the quotes, dbLoadGroup doesn't error out, nor are any
errors printed after iocInit, but pvxgl does not list the table.
Are .json files supposed to be more limited? Or am I doing something
wrong? I couldn't find any docs going in depth into the json files (I
looked at [1] [2] [3]).
[1] https://urldefense.us/v3/__https://epics-base.github.io/pvxs/qgroup.html__;!!G_uCfscf7eWS!ZkcqIYOSuSHnDwdyHQN7hroMlRcHk8MhjbqxVyzSYijS645AhEcpgViz5a4iy70Qd2WTisrt6SnHQkDpbqFDi9HprPU$
[2]
https://urldefense.us/v3/__https://docs.epics-controls.org/projects/pva2pva/en/stable/doxygen/qsrv_page.html__;!!G_uCfscf7eWS!ZkcqIYOSuSHnDwdyHQN7hroMlRcHk8MhjbqxVyzSYijS645AhEcpgViz5a4iy70Qd2WTisrt6SnHQkDpbqFDhPt0pY0$
[3]
https://urldefense.us/v3/__https://docs.epics-controls.org/en/latest/pv-access/Normative-Types-Specification.html*nttable__;Iw!!G_uCfscf7eWS!ZkcqIYOSuSHnDwdyHQN7hroMlRcHk8MhjbqxVyzSYijS645AhEcpgViz5a4iy70Qd2WTisrt6SnHQkDpbqFDRtfc0-4$
Cheers,
Érico
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Using separate .json files for NTTable definitions Michael Davidsaver via Tech-talk
Prev: ADVimba IOC boot recGblRecordError NDPluginDriver errors Rong Huang via Tech-talk
Next: Re: [EXTERNAL] Phoebus settings.ini - Path to predefined Colors and Fonts Dr. Simon Friederich via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: ADVimba IOC boot recGblRecordError NDPluginDriver errors Rong Huang via Tech-talk
Next: Re: Using separate .json files for NTTable definitions Michael Davidsaver via Tech-talk
