1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: ADVimba IOC boot recGblRecordError NDPluginDriver errors
From: Rong Huang via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 18 Nov 2024 13:49:11 -0600
Hi Mark,
Thank you very much for the explanations!
Yes, the detector can collecte images without problems.
Keith was using image processing for data collection controls and I wasn't sure if the NDPluginEdge error message would cause problems during operation which is still running on Keith software. We will try it.
Thanks a lot!
Rong
On Mon, Nov 18, 2024 at 12:48 PM Mark Rivers <rivers at cars.uchicago.edu> wrote:
Hi Rong,
I don’t think any of those messages are too serious.  The driver should be able to collect images, correct?
recDynLinkOut: waiting for CA context
recDynLinkOut: got CA context
Those are normal informational messages.
recGblRecordError: devStringinEnvVar (init_record) Illegal INP parm field Illegal field value PV: 21:FCAMS::TIMEZONE
That message means you are running an older version of iocStats on a newer version of EPICS base.  You should upgrade iocStats,
2024/11/17 22:01:40.703 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2024/11/17 22:01:40.703 NDPluginDriver::writeInt32 ERROR, status=3, function=65, paramName=QUEUE_SIZE, value=2000, connectedToArrayPort_=1
2024/11/17 22:01:40.703 21:FCAMS:Edge1:QueueSize devAsynInt32::processCallbackOutput process write error
I believe all these messages are from NDPluginEdge.  That plugin is not part of ADCore.  I am not sure what is causing those messages.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Rong Huang via Tech-talk
Sent: Sunday, November 17, 2024 10:14 PM
To: tech-talk at aps.anl.gov
Subject: ADVimba IOC boot recGblRecordError NDPluginDriver errors
Hello,
I compiled ADVimba for AVT manta G-146C camera, and tried to start the IOC with a few plugins: ADPluginEdge, SSCAN, devIocStats, and some Calc records. There are a couple of errors after IOC starts:
I am using Ubuntu 22, EPICS-base 7.0.8, areaDetector-R3-13, ADGenICam-R1-10, ADPluginEdge-R1-2, ADVimba-R1-4.
Thank you very much!
The printout of IOC booting:
ls-cat@juniper:/opt/epics/synApps/support/areaDetector-R3-13/ADVimba/iocs/vimbaIOC/iocBoot/iocVimba$ ../../bin/linux-x86_64/vimbaApp st.cmd.original
# modified from st.cmd.manta_G146C as a test
< envPaths
epicsEnvSet("IOC","iocVimba")
epicsEnvSet("TOP","/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADVimba-R1-4/iocs/vimbaIOC")
epicsEnvSet("ADVIMBA","/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADVimba-R1-4/iocs/vimbaIOC/../..")
epicsEnvSet("SUPPORT","/opt/epics/synApps-R6-2/support")
epicsEnvSet("ASYN","/opt/epics/synApps-R6-2/support/asyn-R4-44-2")
epicsEnvSet("AREA_DETECTOR","/opt/epics/synApps-R6-2/support/areaDetector-R3-13")
epicsEnvSet("ADSUPPORT","/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADSupport")
epicsEnvSet("ADCORE","/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADCore")
epicsEnvSet("AUTOSAVE","/opt/epics/synApps-R6-2/support/autosave-R5-11")
epicsEnvSet("BUSY","/opt/epics/synApps-R6-2/support/busy-R1-7-4")
epicsEnvSet("CALC","/opt/epics/synApps-R6-2/support/calc-R3-7-5")
epicsEnvSet("SNCSEQ","/opt/epics/synApps-R6-2/support/seq-2-2-9")
epicsEnvSet("SSCAN","/opt/epics/synApps-R6-2/support/sscan-R2-11-6")
epicsEnvSet("DEVIOCSTATS","/opt/epics/synApps-R6-2/support/iocStats-3-1-16")
epicsEnvSet("ADPLUGINEDGE","/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADPluginEdge")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
epicsEnvSet("ADGENICAM","/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADGenICam")
errlogInit(20000)
dbLoadDatabase("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADVimba-R1-4/iocs/vimbaIOC/dbd/vimbaApp.dbd")
vimbaApp_registerRecordDeviceDriver(pdbbase)
# The maximum image width; used for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE",  "1388")
# The maximum image height; used for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE",  "1038")
# Define NELEMENTS to be enough for a 2464x2056x3 (color) image
epicsEnvSet("NELEMENTS", "5000000")
# The CAMERA_ID can be either of the following:
#  Camera IP address
#  The camera ID, which is the last part of the string reported by arv-tool
# Camera IP address
#epicsEnvSet("CAMERA_ID", "164.54.160.62")
# CameraID, last part of camera name
#epicsEnvSet("CAMERA_ID", "50-0503419258")
# RH: out camera parameters:
epicsEnvSet( "CAM",            "Spindle:")
#epicsEnvSet( "CAM_IP",         "10.1.18.39")
epicsEnvSet("CAMERA_ID", "10.1.18.39")
epicsEnvSet( "PORT",           "PS1")
epicsEnvSet("PREFIX", "21:FCAMS:")
# comment out PREFIX in st.cmd.base
#epicsEnvSet("GENICAM_DB_FILE", "$(ADGENICAM)/db/AVT_Manta_G146C.template")
epicsEnvSet("GENICAM_DB_FILE", "/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADGenICam/GenICamApp/Db/AVT_Manta17594_ip39.template")
# RH: following line removed the message of "recDynLinkOut: waiting for CA context"
var recDynLinkQsize 1024
< st.cmd.base
# Prefix for all records
#epicsEnvSet("PREFIX", "13VMB1:")
# Location of transport layer definition files
epicsEnvSet("GENICAM_GENTL64_PATH", "/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADVimba-R1-4/iocs/vimbaIOC/../../bin/linux-x86_64")
# The port name for the detector
epicsEnvSet("PORT",   "VMB1")
# Really large queue so we can stream to disk at full camera speed
epicsEnvSet("QSIZE",  "2000")
# The maximum number of time series points in the NDPluginStats plugin
epicsEnvSet("NCHANS", "2048")
# The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
# The search path for database files
# This is for Windows
#epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(ADCORE)/db;$(ADGENICAM)/db;$(ADVIMBA)/db")
# This is for Linux
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADCore/db:/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADGenICam/db:/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADVimba-R1-4/iocs/vimbaIOC/../../db")
# ADVimbaConfig(const char *portName, const char *cameraName, size_t maxMemory, int priority, int stackSize)
ADVimbaConfig("VMB1", "10.1.18.39", 0, 0, 0)
asynSetTraceIOMask(VMB1, 0, 2)
# Set ASYN_TRACE_WARNING and ASYN_TRACE_ERROR
#asynSetTraceMask($(PORT), 0, 0xff)
#asynSetTraceFile($(PORT), 0, "asynTrace.out")
#asynSetTraceInfoMask($(PORT), 0, 0xf)
# Main database
dbLoadRecords("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADVimba-R1-4/iocs/vimbaIOC/../../db/vimba.template", "P=21:FCAMS:,R=cam1:,PORT=VMB1")
# Load the autogenerated file of GenICam features
dbLoadRecords("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADGenICam/GenICamApp/Db/AVT_Manta17594_ip39.template", "P=21:FCAMS:,R=cam1:,PORT=VMB1")
# Create a standard arrays plugin
NDStdArraysConfigure("Image1", 5, 0, "VMB1", 0, 0)
# Use this line for 8-bit data only
#dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int8,FTVL=CHAR,NELEMENTS=$(NELEMENTS)")
# Use this line for 8-bit or 16-bit data
dbLoadRecords("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADCore/db/NDStdArrays.template", "P=21:FCAMS:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1,TYPE=Int16,FTVL=SHORT,NELEMENTS=5000000")
# Load all other plugins using commonPlugins.cmd
#< $(ADCORE)/iocBoot/commonPlugins.cmd
# RH use local copy of commonPlugins.cmd to activate a few optionals
<commonPlugins.cmd
# This is an example file for creating plugins
# It uses the following environment variable macros
# Many of the parameters defined in this file are also in commonPlugins_settings.req so if autosave is being
# use the autosave value will replace the value passed to this file.
# $(PREFIX)      Prefix for all records
# $(PORT)        The port name for the detector.  In autosave.
# $(QSIZE)       The queue size for all plugins.  In autosave.
# $(XSIZE)       The maximum image width; used to set the maximum size for row profiles in the NDPluginStats plugin and 1-D FFT
#                   profiles in NDPluginFFT.
# $(YSIZE)       The maximum image height; used to set the maximum size for column profiles in the NDPluginStats plugin
# $(NCHANS)      The maximum number of time series points in the NDPluginStats, NDPluginROIStats, and NDPluginAttribute plugins
# $(CBUFFS)      The maximum number of frames buffered in the NDPluginCircularBuff plugin
# $(MAX_THREADS) The maximum number of threads for plugins which can run in multiple threads. Defaults to 5.
# Create a netCDF file saving plugin
NDFileNetCDFConfigure("FileNetCDF1", 2000, 0, "VMB1", 0)
dbLoadRecords("NDFileNetCDF.template","P=21:FCAMS:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
# Create a TIFF file saving plugin
NDFileTIFFConfigure("FileTIFF1", 2000, 0, "VMB1", 0)
dbLoadRecords("NDFileTIFF.template",  "P=21:FCAMS:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
# Create a JPEG file saving plugin
NDFileJPEGConfigure("FileJPEG1", 2000, 0, "VMB1", 0)
dbLoadRecords("NDFileJPEG.template",  "P=21:FCAMS:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
# Create a NeXus file saving plugin
NDFileNexusConfigure("FileNexus1", 2000, 0, "VMB1", 0)
dbLoadRecords("NDFileNexus.template", "P=21:FCAMS:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
# Create an HDF5 file saving plugin
NDFileHDF5Configure("FileHDF1", 2000, 0, "VMB1", 0)
dbLoadRecords("NDFileHDF5.template",  "P=21:FCAMS:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,XMLSIZE=2048,NDARRAY_PORT=VMB1")
# Create a Magick file saving plugin
#NDFileMagickConfigure("FileMagick1", $(QSIZE), 0, "$(PORT)", 0)
#dbLoadRecords("NDFileMagick.template","P=$(PREFIX),R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
# Create 4 ROI plugins
NDROIConfigure("ROI1", 2000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=21:FCAMS:,R=ROI1:,  PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
NDROIConfigure("ROI2", 2000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=21:FCAMS:,R=ROI2:,  PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
NDROIConfigure("ROI3", 2000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=21:FCAMS:,R=ROI3:,  PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
NDROIConfigure("ROI4", 2000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=21:FCAMS:,R=ROI4:,  PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
# Create 8 ROIStat plugins
NDROIStatConfigure("ROISTAT1", 2000, 0, "VMB1", 0, 8, 0, 0, 0, 0, 5)
dbLoadRecords("NDROIStat.template",   "P=21:FCAMS:,R=ROIStat1:  ,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=21:FCAMS:,R=ROIStat1:1:,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=21:FCAMS:,R=ROIStat1:2:,PORT=ROISTAT1,ADDR=1,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=21:FCAMS:,R=ROIStat1:3:,PORT=ROISTAT1,ADDR=2,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=21:FCAMS:,R=ROIStat1:4:,PORT=ROISTAT1,ADDR=3,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=21:FCAMS:,R=ROIStat1:5:,PORT=ROISTAT1,ADDR=4,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=21:FCAMS:,R=ROIStat1:6:,PORT=ROISTAT1,ADDR=5,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=21:FCAMS:,R=ROIStat1:7:,PORT=ROISTAT1,ADDR=6,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=21:FCAMS:,R=ROIStat1:8:,PORT=ROISTAT1,ADDR=7,TIMEOUT=1,NCHANS=2048")
# Create a processing plugin
NDProcessConfigure("PROC1", 2000, 0, "VMB1", 0, 0, 0)
dbLoadRecords("NDProcess.template",   "P=21:FCAMS:,R=Proc1:,  PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
# Create a TIFF file plugin to read dark and flatfield images into the processing plugin
NDFileTIFFConfigure("PROC1TIFF", 2000, 0, "VMB1", 0)
dbLoadRecords("NDFileTIFF.template",  "P=21:FCAMS:,R=Proc1:TIFF:,PORT=PROC1TIFF,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
# Create a scatter plugin
NDScatterConfigure("SCATTER1", 2000, 0, "VMB1", 0, 0, 0)
dbLoadRecords("NDScatter.template",   "P=21:FCAMS:,R=Scatter1:,  PORT=SCATTER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
# Create a gather plugin with 8 ports
NDGatherConfigure("GATHER1", 2000, 0, 8, 0, 0)
dbLoadRecords("NDGather.template",   "P=21:FCAMS:,R=Gather1:, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
dbLoadRecords("NDGatherN.template",   "P=21:FCAMS:,R=Gather1:, N=1, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
dbLoadRecords("NDGatherN.template",   "P=21:FCAMS:,R=Gather1:, N=2, PORT=GATHER1,ADDR=1,TIMEOUT=1,NDARRAY_PORT=VMB1")
dbLoadRecords("NDGatherN.template",   "P=21:FCAMS:,R=Gather1:, N=3, PORT=GATHER1,ADDR=2,TIMEOUT=1,NDARRAY_PORT=VMB1")
dbLoadRecords("NDGatherN.template",   "P=21:FCAMS:,R=Gather1:, N=4, PORT=GATHER1,ADDR=3,TIMEOUT=1,NDARRAY_PORT=VMB1")
dbLoadRecords("NDGatherN.template",   "P=21:FCAMS:,R=Gather1:, N=5, PORT=GATHER1,ADDR=4,TIMEOUT=1,NDARRAY_PORT=VMB1")
dbLoadRecords("NDGatherN.template",   "P=21:FCAMS:,R=Gather1:, N=6, PORT=GATHER1,ADDR=5,TIMEOUT=1,NDARRAY_PORT=VMB1")
dbLoadRecords("NDGatherN.template",   "P=21:FCAMS:,R=Gather1:, N=7, PORT=GATHER1,ADDR=6,TIMEOUT=1,NDARRAY_PORT=VMB1")
dbLoadRecords("NDGatherN.template",   "P=21:FCAMS:,R=Gather1:, N=8, PORT=GATHER1,ADDR=7,TIMEOUT=1,NDARRAY_PORT=VMB1")
# Create 5 statistics plugins
NDStatsConfigure("STATS1", 2000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=21:FCAMS:,R=Stats1:,  PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1388,YSIZE=1038,NCHANS=2048,NDARRAY_PORT=VMB1")
NDTimeSeriesConfigure("STATS1_TS", 2000, 0, "STATS1", 1, 23)
dbLoadRecords("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADCore/db/NDTimeSeries.template",  "P=21:FCAMS:,R=Stats1:TS:, PORT=STATS1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS2", 2000, 0, "ROI1",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=21:FCAMS:,R=Stats2:,  PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1388,YSIZE=1038,NCHANS=2048,NDARRAY_PORT=VMB1")
NDTimeSeriesConfigure("STATS2_TS", 2000, 0, "STATS2", 1, 23)
dbLoadRecords("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADCore/db/NDTimeSeries.template",  "P=21:FCAMS:,R=Stats2:TS:, PORT=STATS2_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS2,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS3", 2000, 0, "ROI2",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=21:FCAMS:,R=Stats3:,  PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1388,YSIZE=1038,NCHANS=2048,NDARRAY_PORT=VMB1")
NDTimeSeriesConfigure("STATS3_TS", 2000, 0, "STATS3", 1, 23)
dbLoadRecords("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADCore/db/NDTimeSeries.template",  "P=21:FCAMS:,R=Stats3:TS:, PORT=STATS3_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS3,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS4", 2000, 0, "ROI3",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=21:FCAMS:,R=Stats4:,  PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1388,YSIZE=1038,NCHANS=2048,NDARRAY_PORT=VMB1")
NDTimeSeriesConfigure("STATS4_TS", 2000, 0, "STATS4", 1, 23)
dbLoadRecords("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADCore/db/NDTimeSeries.template",  "P=21:FCAMS:,R=Stats4:TS:, PORT=STATS4_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS4,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS5", 2000, 0, "ROI4",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=21:FCAMS:,R=Stats5:,  PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1388,YSIZE=1038,NCHANS=2048,NDARRAY_PORT=VMB1")
NDTimeSeriesConfigure("STATS5_TS", 2000, 0, "STATS5", 1, 23)
dbLoadRecords("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADCore/db/NDTimeSeries.template",  "P=21:FCAMS:,R=Stats5:TS:, PORT=STATS5_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS5,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
# Create a transform plugin
NDTransformConfigure("TRANS1", 2000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDTransform.template", "P=21:FCAMS:,R=Trans1:,  PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
# Create an overlay plugin with 8 overlays
NDOverlayConfigure("OVER1", 2000, 0, "VMB1", 0, 8, 0, 0, 0, 0, 5)
dbLoadRecords("NDOverlay.template", "P=21:FCAMS:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
dbLoadRecords("NDOverlayN.template","P=21:FCAMS:,R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=21:FCAMS:ROI1:MinX_RBV,YPOS=21:FCAMS:ROI1:MinY_RBV,XSIZE=21:FCAMS:ROI1:SizeX_RBV,YSIZE=21:FCAMS:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=21:FCAMS:,R=Over1:2:,NAME=ROI2,   SHAPE=1,O=Over1:,XPOS=21:FCAMS:ROI2:MinX_RBV,YPOS=21:FCAMS:ROI2:MinY_RBV,XSIZE=21:FCAMS:ROI2:SizeX_RBV,YSIZE=21:FCAMS:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=21:FCAMS:,R=Over1:3:,NAME=ROI3,   SHAPE=1,O=Over1:,XPOS=21:FCAMS:ROI3:MinX_RBV,YPOS=21:FCAMS:ROI3:MinY_RBV,XSIZE=21:FCAMS:ROI3:SizeX_RBV,YSIZE=21:FCAMS:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=21:FCAMS:,R=Over1:4:,NAME=ROI4,   SHAPE=1,O=Over1:,XPOS=21:FCAMS:ROI4:MinX_RBV,YPOS=21:FCAMS:ROI4:MinY_RBV,XSIZE=21:FCAMS:ROI4:SizeX_RBV,YSIZE=21:FCAMS:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=21:FCAMS:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=4,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=21:FCAMS:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=5,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=21:FCAMS:,R=Over1:7:,NAME=Box1,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=6,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=21:FCAMS:,R=Over1:8:,NAME=Box2,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=7,TIMEOUT=1")
# Create 2 color conversion plugins
NDColorConvertConfigure("CC1", 2000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDColorConvert.template", "P=21:FCAMS:,R=CC1:,  PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
NDColorConvertConfigure("CC2", 2000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDColorConvert.template", "P=21:FCAMS:,R=CC2:,  PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
# Create a circular buffer plugin
NDCircularBuffConfigure("CB1", 2000, 0, "VMB1", 0, 500, 0)
dbLoadRecords("NDCircularBuff.template", "P=21:FCAMS:,R=CB1:,  PORT=CB1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
# Create an NDAttribute plugin with 8 attributes
NDAttrConfigure("ATTR1", 2000, 0, "VMB1", 0, 8, 0, 0, 0)
dbLoadRecords("NDAttribute.template",  "P=21:FCAMS:,R=Attr1:,    PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048,NDARRAY_PORT=VMB1")
dbLoadRecords("NDAttributeN.template", "P=21:FCAMS:,R=Attr1:1:,  PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=21:FCAMS:,R=Attr1:2:,  PORT=ATTR1,ADDR=1,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=21:FCAMS:,R=Attr1:3:,  PORT=ATTR1,ADDR=2,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=21:FCAMS:,R=Attr1:4:,  PORT=ATTR1,ADDR=3,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=21:FCAMS:,R=Attr1:5:,  PORT=ATTR1,ADDR=4,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=21:FCAMS:,R=Attr1:6:,  PORT=ATTR1,ADDR=5,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=21:FCAMS:,R=Attr1:7:,  PORT=ATTR1,ADDR=6,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=21:FCAMS:,R=Attr1:8:,  PORT=ATTR1,ADDR=7,TIMEOUT=1,NCHANS=2048")
NDTimeSeriesConfigure("ATTR1_TS", 2000, 0, "ATTR1", 1, 8)
dbLoadRecords("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADCore/db/NDTimeSeries.template",  "P=21:FCAMS:,R=Attr1:TS:, PORT=ATTR1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ATTR1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
# Create an FFT plugin
NDFFTConfigure("FFT1", 2000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDFFT.template", "P=21:FCAMS:, R=FFT1:, PORT=FFT1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=VMB1, NAME=FFT1, NCHANS=1388")
# Create 2 Codec plugins
NDCodecConfigure("CODEC1", 2000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDCodec.template", "P=21:FCAMS:, R=Codec1:, PORT=CODEC1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=VMB1")
NDCodecConfigure("CODEC2", 2000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDCodec.template", "P=21:FCAMS:, R=Codec2:, PORT=CODEC2, ADDR=0, TIMEOUT=1, NDARRAY_PORT=VMB1")
# Create a bad pixel plugin
NDBadPixelConfigure("BADPIX1", 2000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDBadPixel.template", "P=21:FCAMS:, R=BadPix1:, PORT=BADPIX1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=VMB1")
set_requestfile_path("./")
set_requestfile_path("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADCore/db")
set_requestfile_path("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADCore/iocBoot")
set_requestfile_path("/opt/epics/synApps-R6-2/support/autosave-R5-11/db")
set_savefile_path("./autosave")
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
save_restoreSet_status_prefix("21:FCAMS:")
dbLoadRecords("/opt/epics/synApps-R6-2/support/autosave-R5-11/db/save_restoreStatus.db", "P=21:FCAMS:")
dbLoadRecords("/opt/epics/synApps-R6-2/support/autosave-R5-11/db/configMenu.db", "P=21:FCAMS:, CONFIG=ADAutoSave")
# Load NDPluginPva plugin
NDPvaConfigure("PVA1", 2000, 0, "VMB1", 0, 21:FCAMS:Pva1:Image, 0, 0, 0)
dbLoadRecords("NDPva.template",  "P=21:FCAMS:,R=Pva1:, PORT=PVA1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
#Must start PVA server if this is enabled
startPVAServer
# Optional: load ffmpegServer plugin
#ffmpegServerConfigure(8081)
#ffmpegStreamConfigure("FfmStream1", 2, 0, "$(PORT)", 0, -1, 0)
#dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegStream.template", "P=$(PREFIX),R=ffmstream1:,PORT=FfmStream1,NDARRAY_PORT=$(PORT)")
#ffmpegFileConfigure("FfmFile1", 16, 0, "$(PORT)", 0, -1, 0)
#dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegFile.template", "P=$(PREFIX),R=ffmfile1:,PORT=FfmFile1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(FFMPEGSERVER)/db")
# Optional: load NDPluginEdge plugin
# RH activate EdgePlugin
NDEdgeConfigure("EDGE1", 2000, 0, "VMB1", 0, 0, 0, 0)
#dbLoadRecords("$(ADPLUGINEDGE)/db/NDEdge.template",  "P=$(PREFIX),R=Edge1:, PORT=EDGE1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
set_requestfile_path("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADPluginEdge/db")
dbLoadRecords("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADCore/db/NDEdge.template",  "P=21:FCAMS:,R=Edge1:, PORT=EDGE1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
# Optional: load NDPluginCV plugin
#NDCVConfigure("CV1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
#dbLoadRecords("$(ADCOMPVISION)/db/NDCV.template",  "P=$(PREFIX),R=CV1:, PORT=CV1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(ADCOMPVISION)/db")
# Optional: load NDPluginBar plugin
#NDBarConfigure("BAR1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
#dbLoadRecords("$(ADPLUGINBAR)/db/NDBar.template",  "P=$(PREFIX),R=Bar1:, PORT=BAR1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(ADPLUGINBAR)/db")
# Optional: load scan records
# RH activate SSCAN
dbLoadRecords("/opt/epics/synApps-R6-2/support/sscan-R2-11-6/db/scan.db", "P=21:FCAMS:,MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10")
set_requestfile_path("/opt/epics/synApps-R6-2/support/sscan-R2-11-6/db")
# Optional: load sseq record for acquisition sequence
#dbLoadRecords("$(CALC)/db/sseqRecord.db", "P=$(PREFIX), S=AcquireSequence")
#set_requestfile_path("$(CALC)/db")
# Optional: load devIocStats records (requires DEVIOCSTATS module)
# RH activate devIocStats
dbLoadRecords("/opt/epics/synApps-R6-2/support/iocStats-3-1-16/db/iocAdminSoft.db", "IOC=21:FCAMS:")
# RH add this two modules currently used at LS-CAT:
dbLoadRecords("/opt/epics/synApps-R6-2/support/calc-R3-7-5/calcApp/Db/yySseq.db", "P=21:FCAMS:, S=AcquireSequence")
dbLoadRecords("/opt/epics/synApps-R6-2/support/calc-R3-7-5/calcApp/Db/userCalcOuts10.db", "P=21:FCAMS:")
# Optional: load alive record (requires ALIVE module)
#dbLoadRecords("$(ALIVE)/db/alive.db", "P=$(PREFIX),RHOST=192.168.1.254")
# Set the callback queue size to 5000, up from default of 2000 in base.
# This can be needed to avoid errors "callbackRequest: cbLow ring buffer full".
callbackSetQueueSize(5000)
set_requestfile_path("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADGenICam/GenICamApp/Db")
set_requestfile_path("/opt/epics/synApps-R6-2/support/areaDetector-R3-13/ADVimba-R1-4/iocs/vimbaIOC/../../vimbaApp/Db")
# RH added: (this increases connected PVs from 3764 to 5237!)
set_requestfile_path("/opt/epics/synApps-R6-2/support/calc-R3-7-5/calcApp/Db")
iocInit()
Starting iocInit
## EPICS R7.0.8
## Rev. 2024-06-13T17:42-0500
## Rev. Date build date/time:
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30,"P=21:FCAMS:")
epics> auto_settings.sav: 5237 of 5237 PV's connected
ADVimba IOC boot recGblRecordError NDPluginDriver errors Rong Huang via Tech-talk
RE: ADVimba IOC boot recGblRecordError NDPluginDriver errors Mark Rivers via Tech-talk
Prev: RE: Asyn device support does not reconnect Mark Rivers via Tech-talk
Next: Re: Including display information in NTTables Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: RE: ADVimba IOC boot recGblRecordError NDPluginDriver errors Mark Rivers via Tech-talk
Next: Using separate .json files for NTTable definitions Érico Nogueira Rolim via Tech-talk
ANJ, 18 Nov 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
